Stripped chainring bolt
Any suggestions on how to remove a stripped chainring bolt? Im trying to replace my existing chainrings with larger ones. Thanks in advance.
I’ve had to do this before. The solution is pretty simple: get a drill and start with a bit that’s just a little larger than the allen key hole. Drill it with progressively larger bits. When you get close to the size of the bolt hole, the remnants of the bolt will be easy to pull out with some pliers. Aluminum alloy is very easy to drill. It’s a little bit harder if the bolts are steel.
–jens
Not sure what you mean by stripped. They usually break and fall apart. They come in different configurations depending on the crank but most are two part, a male threaded front and a female threaded nut. . If you have one that is just rotating without loosening itas likely that the nut that the bolt threads into is rotating, this is common and a bike shop will have a special tool for holding it steady. In a pinch a large flat screwdriver will also work.
Styrrell
