Stretch for Rhomboid muscle
I have had a sharp pain beneath my shoulder blade for what has seemed forever when biking.
It’s not an issue with bike fit , it occurs on my mountain bike, motorcycle, tri bike etc. Over the years chiropracters have done nothing to change the symptoms.
The Rhomboid muscle seems to be the culprit, is there a stretch that works that muscle beneath the shoulder blade?
Thanks
Ron W.
Beneath the scapula is the serratus and the subscapularis, the rhomboid runs from the edge of the scapula towards the spine.
So is the pain underneath the scapula (subscap), below it (lat), or between the two blades (rhomboid)? Do you get the pain when standing and using your arms for prolonged periods? (think work bench or kitchen counter working) Could be more of a strength issue, than tightness of the muscle, or a positional problem with the shoulder blades. Has anyone looked at your posture, or for muscle imbalances? Pain can come from multiple structures, and there’s a plethora in the scapular region…i’m just tossing out some of the main ones.
Either way, to answer your stretch question, you can try inter-twining your fingers with straight arms, then try to arch your upper back, which moves the shoulder blades apart from each other. Tuck your chin down to your chest, then move your arms slowly to the side, like a golfer putting. Vary the height of your arms to dial it in a bit. See if you feel that in the upper back between the blades.
Getting the subscap, lats, etc stretched are totally different movements, so i’m trusting you’ve identified what needs the stretch. good luck!
Give someone a hug. Scapular protraction will stretch the rhomboids a bit.
Great idea ! my wife will love that stretch…
I have problems in that general area and I like to lie on a tennis ball. If that’s too intense, you can put a tennis ball into a sock, sling it over your shoulder and press up against a wall.
Did you ever find a solution? I have the same problem and haven’t found any way to solve it.
I had this for years and it was a huge muscle imbalance. Probably more accurate to say an absence of muscle in my subscap region…granny weak:/ Tons of band rows from low, mid and high attachment points and it slowly went away. Never fast and hold the handles in your finger tips…it makes sure you can’t use your biceps or anything but your scap to do the work!
x2
Google “blackburn exercises”
Possably tight pecks drawing your shoulders forward, possible posture at work/sleep etc. Rhomboids and mid traps are tight and long as opposed to tight and short.
Heat for 20 min on back, then use the tennis ball or golf ball, let it roll into those tight areas, leave it there for 10sec per spot, then make sure you stretch them out. See a good massage therapist or physio that also does ART, they can also give you strengthening exercises to decrease the strain.
I know you said that Chiro work had not helped but there are referral patterns from the Cervical spine that send pain down along the medial boarder of the Scapula…have you had any imaging done for loss of Disc height/herniation, arthritic changes at the facet or neural foramen?
