i have had an injury caused by over training on the bike and although i have been to many physios and sports doctors regarding this issue,none seem to have a conclusive answer. it manifests itself as a pain about 2 inches below the patella and directly in the centre of the leg. applying pressure to the pedals seem to be the aggravating stimuli.
anyone experienced this injury or have any thoughts on it??
Try this stuff http://www.tpmassageball.com/ it’s amazing.
I’ve had pain similar to what you describe and it was linked back to a tight IT band pulling the patella off track.
the physios is farely satisfied that it is not related to the itb, initally it was thought to be linked with weak core stabilisers muscles causing the hip flexer to be over loaded with work.
the remedy for me was a steroid injection directly into the problem zone(below knee). but this is not a solution rather a temporary fix.
I had this problem on my right leg, downhill and XC skiing did the trick. I think my quads, stabilizers, hip flexors and hamys were weak. Now no problems, knock on wood. Do you have XC skiing nearby? It’s a good way to get a great workout without the trauma from running.
what is the idea behind training on the skiier??..just to minimise impact??
Is the pain on the bump on the tibia where the patella tendon inserts into the tibia? If it is I will have some addit. recs…
yes that sounds pretty close to the problem area…any ideas??
Sound like patella tendinits…would be prone to it cycling because pushing the pedal down fires the patellofemoral mechanism alot (that’s why we get big quads)…my suggestions: try to spin more than grind big gears 'til better, warm up very easy, work on stretching the quad and patella tendon (hyperflexing the knee by bringing the foot to the butt), avoid kneeling or crawling to avoid putting pressure directly on this area, ice to area after workout, possibly adding heat to area before stretching, short tern usage of antiinflammatories while working on other stuff, avoiding running hills temporarily while trying to get better…IF this doesn’t work(give it a few weeks), can add physio treatments to area or even a cortisone injection as a last resort if everything else is failing…any questions let me know…
Patellar tendonitis and pain is often caused by a saddle that is either too low or too far forward or both. Is your saddle height correct?
the injury has flared up twice. the first time because of 500 miles on the bike in four days and the second time because of running a half marathon while not in great shape. the common factor seems to be over training.
FWIW, I had similar symptoms, more so in one knee than the other. I got a sinus infection around Christmas, Dr. gave me antibiotics etc. This included a steroid dose pack. After three days of sitting on my butt, plus the steroid I felt great on my first run since coming down with the cold. I’m sure the steroid helped but I’m sure the three days of complete rest helped a ton. You may just have to rest 3-4 days. That means no biking or running. Good Luck!
have tried resting on it…have rested for 14 days doing nothing only what is necessary to commute. ie. a 5 minute walk to the bus and some light walking during the day. maybe the steroid played a bigger part than you thought
how old are you, maybe osgood schlatter disease, though patellar tendonitis sounds good too
You’re probably right. Morale is, if you’ve got some nagging tendonitis, try to get sick so you can get some steroids. ![]()
i am 23 and only in the sport 2 years
Not sure if this is what you have but it’s worth a try. I had the same thing you describe and PT’s and Chiros couldn’t figure it out. It turned out that it was from really really tight hamstrings especially behind and right above the knee. When I focused on really stretching my hamstrings a lot, the pain went away completely.
Try it. Good luck
