Stock frames for tall riders? Or do I go custom?
I’m a bit taller than your average triathlete (a bit over 6’5"), which seems to eliminate pretty much any stock frame other than Cervelo’s 61’s. Two questions:
  1. Any other stock frames that might fit?
  2. If I go custom, I know I can get Guru, Litespeed, Elite, and some of the smaller shops. I think I remember hearing that SOME QRoo frames are available custom - if so, which ones? What other makes (that offer good bang for the buck) should I consider? How proficient are companies with roadie pedigrees like Serotta and Seven with tri geometry and aerodynamics?
Whatever I get, I’ll be sure the seat isn’t too high…
Thanks in advance.
M
A lot of stock road frames will fit a guy your size, but I assume you mean tri bikes?
Since I’m only 5’9", this is not really my territory, but I do have a friend who is your height and he was riding a Litespeed Blade and as just switched to a Blue. I’m not sure what size frames these are, but they are both stock frames.
“Speedy” Gonzales is a Blue dealer, so hopefully he will see this and maybe help you out.
Yep, definitely a tri bike.
www.fujibikes.com
The Aloha CF1 and CF2 as well as the aluminum Aloha in a 62cm have 59.5 toptubes.
“How proficient are companies with roadie pedigrees like Serotta and Seven with tri geometry and aerodynamics?”
That’s been much debated on this forum in the past. Hopefully we won’t have to re-live it.
yaqui is the gold standard for custom tri bike fit, IMO.
It depends on proportions. If you have extra long legs then you may need to approach a builder who can build something custom or semi-custom like the Yaqui that H2ofun bought. He had a hard time fitting on normal stock frames and he is your size.
Chad
For an average training bike
Cinelli in steel , Cannondale , A few old Japanese frames " lotus " 67cm. You “can ride a smaller frame.
I don’t like the lack of comfort on the smaller frames.
6’ 6” my 65 cm is comfortable . Some Colnagos came in larger frames.
                                                    Heli.
I’m 6’6" and there are a number of 61cm stock frames that work for me. That said I went with a custom Yaqui for my tri-bike, but I have a stock Specialized road bike and ride an old 62 Univega converted to a fixed gear through the winter.
For stock tri frames look at QR, Litespeed, and Cervelo. From my test rides they all were big enough to get a good fit. As I recall the Blade I tried was a bit big in the top tube.
scott
I have a few guys your size riding Blue Competition T14’s. Michael Hay is one of them. You can check out his bike on my website’s photo gallery if you are curious.
Have you had a bike fit done? If so, can you PM me the measurements. I’ll send the data over to my bike fitter & see if we can help you.
Thanks for the plug Cerveloguy. Just to be clear, my company is the Canadian distributor & not a dealer. Also, my last name is Gonsalves not Gonzales. The name thing is not a biggie, it happens all the time.
It really depends on your position and where you are comfortable. I’mm 6’6" with long legs and I ride a 61cm Cervelo (P2K) and it feels a little big. I’ve got a 70cm stem and have the pads jammed right at the back to get comfortable but I really like the setup. I would consider a slightly smaller bike next time though to get a bit lower. My primary road bike is a 63cm Cannondale and it fits like a glove so my next bike will probably be a System Six but Guru has been in the running as well if I needed custom.
I’m 6’6". My body proportions require a long seat tube but short top tube. My tope tube has a 1.5 deg down slope to the seat tube. If it was horizontal, the center to center measurement (BB to center of TT) would be 66cm. My TT is 59.5. I went with a custom frame from Roark. Been extremely happy. Do a search on this forum. I know they’ve been talked about a few times.
wow, you just beat me in the frame size category. My road bike and CX/fixie are both 64 ctc and 58 TT;
Our Aloha’s should fit you. I’m 6’ 5" 220 and I fit really well on them. Best bet, get measured and then apply your measurements to a few different bikes to see what will fit you best. FIT is still the most important thing. You may need to customize your stem, cranks, bars, etc. but any good shop will do that for you.
If you have questions, feel free to call me. I’m leaving for Taiwan tonight but I’ll be here until 3 today.
215.824.3854 Ext. 1111
I am 6’5" and went with Ves and hit Yaqui Tri bike. You send him all the measurements, and he can tell you whether or not you need a custom frame. He fitted me to a 59 std and it fits like a GLOVE!!!
As has always been said, FIT,FIT!! Just because you are tall, does not mean you need a custom or huge TT frame. From what I have seen, TT frames are smaller for us big guys than road frames.
The other thing you need to get if correct crank arms!! I just went to 200’s and have had the fastest 5/5 bike times on my 30 mile hilly TT course. Do not let any short person say you dont need custom longer cranks, even Ves. :o)
Dave
My opinion, if you’re 6’5"+ and your going to drop $3000 or more on a tri bike, why not go custom? If you’re looking for an entry level ride at a lower price point, then maybe try to fit on a stock frame. I’m partial to Litespeed myself. Litespeed doesn’t charge much extra to build custom. You can get the QR titanium model custom as well.
I’m also a fan of longer crankarms for tall riders and 54 tooth chainrings, but that’s based on my experience and what works well for me.
Until you send you measurements to someone who knows what they are doing, one does not know if a custom frame is needed. I fully expected Ves to tell me I needed a custom frame from him, but it turned out that I fit just perfect on a 59cm, even at 6’5.
I LOVE my 200mm cranks also, but I have them on a compact crank setup which works great for me in all the big hills I do.
Dave
I’m at 6’2" and on a 56cm Felt frame. The 60cm triathlon frames have nearly 60cm top tubes. There are a number of 6’5" and taller guys on Felt 60cm frames.
Not to beat a dead horse, but fit is more important than a sticker with a measurement on them.
Regards,
SD
I’m 6’4" and a bit. I ride a 61cm QR. It fits very well but my inseam is only 32in. My brother is 6’9" and is looking at a Giant compact geometry frame.
I’m 6 ft 4, and had stock bikes. I’m not super tall, normal ranges etc, but I finally put the down payment on a custom frame…why try to fit, when you can fit…know what I mean.
Then again, some shops deal with so many manufacturers, that they can really tailor you to the best fit. We all hope that happens…
Go custom…do it right
Hey, for my 2 cents: I’m 6’5", 34 in inseam (so I’m long in the torso). Just had a bike fit last week. Recommendation / bikes that fit are the 61 P2C and swap out the bars to boost my upper body up a bit. P3 has a shorter down tube and wouldn’t work as well. Guru would fit as well since they can customize it. Kuota, giant, specialized wouldn’t work.
