I currently have a Ritchey 100mm stem and I’m looking for something shorter maybe 80 to 90mm. I have the stem reversed (+/- 6) to give more rise. I’m using Vision Tech base bar which is 26.0mm. Any 80mm suggestions with some rise? I know 90 isn’t a problem but I feel 80 would be better. What are the difference between road and mtb stems. Are mtb stems a different slightly small 25.4mm?
I have an 80mm that I can TSR to you - get me your address. It is a Vision FSA - 80 degree rise…
So, I can send it out today even if I get your address soon enough.
Chip,
Would you have a black 120 with a 6/10 degree rise? If so, I’ll trade you my no name silver, or I have a Thompson 110.
Sorry, no 120mm at all.
However, for the other I found a Profile Design stem too…H20, so, you want the Vision or the Profile?
Vision would be great. Thanks
I’ve been riding a 100 and have been looking at going to an 80 also. I will probably get the Ritchey adjustable so I can tweak the height a bit.
