I have the Deda Synapsi intergrated stem and aero bars and one of the stem bolt threads is gone…i cant screw a bolt on properly…what should I do? i would say i need to create a new thread pattern so to speak…or perhaps try different bolts…
I hope you have more luck than I did with my Deda Mag00 that I stripped the thread of one hole in Brasil. Since then I only use 4 bolt stems and do not buy Magnesium stems. Good Lukc, Stephen.
hey Julain.,…good to hear you’re oka man…thanks
Bring it to a good bike shop. They should be able to retap the thread. And then buy a torque wrench so you don’t overtighten it next time.
Jeff
thanks man…but what does retap mean…
Essentially, retapping a thread is running a thread cutter (a tap) through an existing thread, slightly larger to enable it to still be utilised.
It can be done, should not be a huge problem. May have to go with a slightly larger boly, but get someone to tap it and like someone above mentioned, torque wrench! Get used to it. With all the fancy carbon/ti/magnesium parts around these days, it is becoming very common to over-torque these bolts. We are putting on warning decals and laser etching the nuts for our bikes at our plant now so our shops dont go crazy with the wrenches!
thanks a lot guys appreciate it
