After my last post about the theories of what the ‘proper’ seat angle is, i’ve taken 4 paragraphs and thought on them. 2 supporting steep riding by Rappstar and Slowman, and 2 supporting a slack angle by 2 Cyfac reps. Here they are:
“Even if it was true that a super steep position completely saved your legs for the run, it would have a negative impact on overall performance.”–Cyfac
“But the shallow-is-better view flies absolutely contrary to almost all of what we’ve seen over the past few years in timed eventing, both in triathlon and in bike racing.”–Slowman
“The energy cost of moving forward as Empfield, et al, recommend is also something to consider. Namely, the use of musculature is restricted by moving so far forward, and this means that fewer muscles are doing more work. The further forward you move out of your optimal range, the more you use your quads to do all the work. A more efficient way to generate power is to spread that energy cost across a great number of muscles. Moving so far forward forces your body to work twice as hard to do the same amount of work, the end result is quicker depletion of your energy stores, and a greater tendency to cramp through a more rapid depletion of electrolytes–this is especially true for longer events.”–Cyfac
"Sorry, but that makes no sense. Why would you want to use your running muscles for both running and cycling? Riding steep, generally speaking, minimizes the use of the prime movers for running - your hamstrings. This is a bit of an oversimplification, but basically, riding steep helps to save your legs for running; it does not cause you to use “more of your ‘run’ muscles.”—Rappstar(stud triathlete)
After thinking on this I came to a conclusion based on such a huge assumption that i’m afraid to pose the question for fear I may be considered a troll. I’m not a troll, and I don’t want to start a pissing match. I just want to put this out there since i’m going in for a retro fit next week and want to figure this out:
Based on performance in each individual sport that makes up a ‘triathlon,’ it seems to me that swimmers are swimming faster, runners are running faster, and cyclists are cycling faster (huge assumption #1) based on World Records falling and things like ‘average speed’ for the Tour de France. It also seems to me that triathletes aren’t getting faster, and may be getting slower (huge assumption #2).
Could this be the ‘long term’ cost of riding steep?
