What is the disadvantage of having too much distance from the ball of your foot to the pedal axle?
You need a little more ankle strength and will use a little (miniscule) more energy keeping your foot stable. Also and this gets very picky for the same bike for every mm of height your body is raised a mm whcih hurts aerodynamics.
Styrrell
I personally don’t think there is that big of difference in the real world. The engineers on this forum might be able to give you a technical answer. There are two different systems on the market that greatly reduce stack height. I have ridden one of them. Here are the links to the systems.
http://www.easys.biz/index_2.html - in french
http://www.sidemountpedal.com
