Well, I was browsing the classifieds with a friend right after IMLP on Monday afternoon as he was in the market for a powermeter…then Jens’ post for a compact SRM with 50/34 chainrings and 170 mm cranks pops up for $1100.
I was just discussing 30 minutes earlier how I was planning to go to 170 cranks after LP, so my friend Paul (not me, the other guy) says, hey, you’re going to spend $200 on new cranks anyway, and this would be perect to you, so now you are down to $900.
I noticed that the seller is Jens who lives just outside Palo Alto. I was going to fly from Ottawa to San Francisco the next day and then driving down to San Jose, so a trip to Jens’ would be a short detour with my rental car. 24 hours later, I’m at Jens’ place in California and getting all the details on the install. We try to figure out how I can pay him on the spot, but really have no options as I don’t have money loaded up into the paypal account we created. So Jens sends me off for a week of business trusting my honesty and then I got home and finally got it all installed this evening. Tuesday when banks open I can actually cut a certified cheque and fire it his way.
Pretty cool though that someone would pretty well hand off a pretty expensive piece of bike kit to a person who he just met for the first time in his life.
Anyway, can’t wait to get going tomorrow and finally Chris G and ML can stop hounding me about not spending on a powermeter…
Is this going to be your first ride outside with power ever? If so, I predict you’ll be amazed at how much power you put out going uphills and how little you put out going downhill for a given RPE.
Yeah, definitely first time outdoors. I don’t expect to be too shocked uphills, where I am generally pretty good at holding back (you never see me shooting passed the guys with the big PT hubs in racing). Where i expect to see stupidly low numbers are tailwind flats and false flat downhills. I would imagine that I would see high numbers that are not sustainable when riding into strong headwinds too…anyway, will be fun.
Holy smokes. You got it installed already? That was quick! The bottom bracket sensor is tricky the first time around on many TT bikes. If you search around the posts here you’ll see a few different methods: electrical tape; zip ties; velcro, etc.
Anyhow, I just realized after you left that I had an extra handlebar mount on my road bike. If you send me your address, I’ll ship it off to you.
Well, I was all excited to use it this morning. I have a 90K loop from home that has 50K on flats and 40K in hills so a good combination of terrain to see what is going on. Anyway, I was 5K from home and the unit blanks out on me. I guess I did not charge it for long enough, but up to then I was getting power, speed, cadence. I did find out that while riding on the flats at 180 W if I dropped my head, the wattage immediately went to 170 for the same effort…that was the extent of the revelations. Never got to the hills to give you guys uphill and donwhill and false flat data.
However, I did have a good 90K ride with shorter 170 cranks and it did feel easier staying aero and interestingly enough riding out of the saddle was easier even with less leverage (I guess slightly more open hip angle at the top). So for the moment, the first ride was a good experiment on some really expensive shorter cranks
Here is an update for Chris G and ML. I actually got to use the unit today but it was raining and I did not have a lot of time (takes me like 60 min to warmup in the rain), so I got on my insideride rollers and did a 25 min ride with 8x1 min hard. What I found was that my insideride roller charts that translate speed to wattage at the various mag settings were approximately 10W off at each speed (their formula uses rider+bike weight, speed, mag setting all at 100 psi), but I am glad to say that the insideride guys were pretty accurate, at least close enough to consistently use for quantifiable training if you don’t have a power meter. So what I thought was 300W was only ~290, what I thought was 180, was only ~170.
Anyway, tomorrow group ride with the boys before work (same 90K loop as Sunday, with the 40K hilly section being the group ride session), so I’ll be able to report back. At lunch time, I gotta go get the certified cheque cut for Jens so that ST does not do a lynch mob scene on me ( lilke the entire Jasongk thing…)
I don’t remember what slope is currently on the unit. The last time I calibrated it, it was 18.79. It’s probably worth checking again sometime. Also, don’t forget to set the 0 offset before each ride. That can sometimes make a 5-10 watt difference if there have been significant temperature changes.
And, of course, bear in mind that power at the crank (i.e. the SRM) should be 5-10 watts higher than power at the hub or on the roller (because of drivetrain power losses).
