I am looking for an inexpensive way to get low gearing for a tri bike to allow some of the local flatlanders with one (tri) bike to do a couple mountain centuries this year.
It looks to me like the cheapert way to get small gear-inches is to install a long cage rear derailleur and mountain bike cassette along with a 9 speed bar end shifter.
My question is will a 9-speed Dura Ace shifter index a Shimano mountain bike rear derailleur (no 10 speed MTB cassettes out there)?
Appreciate the likely advice for compact cranksets - I run them on my tri and road bikes, but I am looking for the lowest cost solution for riders without a lot of scratch to drop on a compact and a new cassette.
First mountain ride is Mountains of Misery in Blacksburg this Memorial Day weekend. Over 10K of climbing in 102 miles or over 13K in 200K of riding. Appreciate any help y’all can provide.
No problem on the DA shifter along with whatever Shimano long cage rd. Not running a triple up front means you can probably get away with a mid-cage. Just ask at your LBS. No 10sp for mtb, some bad condition reliability was lost in going from 8 to 9, so I'm sure they'd have an awful time foisting 10s on the offroad crowd.
IRD makes some wide range, 10 speed cassettes including a 12-32 and 11-32. IRD website. While I know that they are out there we haven’t actually installed any of them yet. If you were to use one you would need a MTB derailleur. The combination of the IRD cassette and a mtb derailleur should work with 10 speed indexed STI or barend shifters.
IRD makes some wide range 9 speed cassettes too but you could just use Shimano ones.
Check with your LBS if you want one as they are available through normal distributors including QBP.
33 is the reccomended chain wrap for a medium cage xt derailleur with the max cog size of 34. if your chain wrap is really 37, i would go with a long cage. that’s a pretty big range you go there, but I don’t know what you’ll be riding either.
Thanks Crash - I haven’t gotten around to checking tooth capacity of the derailleurs yet. It will be for my girlfriend’s bike and maybe a few other folks from our club. I’ll be on a Soloist with a compact crankset and 12-27 cassette.
