How often should you change your helmet?
OR
How often DO you change your helmet?
JC
OR
JC
I think I’ve read that it’s recommeded to retire a helmet every 3 years. That’s probably marketing at it’s best and would think a helmet is probably still good well after 3 years…
every time you give it a decent knock which for me is less than every three years in any event. Always assumed this was hype till I found two monster cracks in mine from a crash a month ago which barely scratched the glossy plastic top
Have also just discovered (and I don’t work for either company) that Madison - the UK importers of Giro helmets- will give you half the value of a cracked Giro helmet of the cost of a new one. Your LBS should have the details if this helps at all
Excellent. Thanks for the info. No use now though as placed order for my new Giro ‘Pneumo’ yesterday… Thanks again tho!
JC
