SRM Wireless FSA K-Force Light 2 rides
Kharma’s a bitch. Literally 12 days after purchasing this thing I get laid off from my job.
~115 miles. No scuffs. Obviously in great shape. That is why I am asking $3000 for it. PM me with questions.
Length is 172.5mm
The entire SRM system goes wireless! The SRM FSA K-Force Light Wireless power meter and PowerControl VI features brand new, completely redeveloped technology. Wireless data transmission from the SRM PowerMeter is done through the ANT+Sport protocol to guarantee the highest reliability and accuracy in data transmission. Other improvements of the PowerControl VI over previous models include integrated altitude measurement and storage. Storage capacity has been significantly increased to 1054 hours at 1 second intervals versus the 6.2 hours of the PowerControl V. A new USB interface allows charging directly through your computer. Finally, the menu navigation has been simplified and new icons on the clearly legible, high-contrast display improve functionality during training.
The SRM Wireless power meter is the only choice in premium power meters. It has fantastic machine work and build quality. More top athletes and coaches recognize SRM power meters as the default choice where the best function and performance is required. It’s design allows you to change rear wheels and has a proven reputation of holding up to a lot of hard use.
The Wireless FSA K-Force Light compatible SRM was also designed to accommodate frames with larger bottom bracket diameters such as the Giant, Scott, and Trek. The new wireless power meter design has a 50 mm inside diameter to work with all frames that use the integrated bottom bracket.
Wireless fork sensorWireless skewer sensorFSA Ceramic BB
FeaturesCeramic BB included(BSC thread)53/39 chainrings50 mm inside diameter812 grams with crank and chainringsWireless ANT+Sport protocolExcellent machine work and build qualityIncludes wireless PowerControl VI with new technologySuunto ANT+ Sport heart rate strapNow compatible with frames with larger bottom bracket diameters such as the Giant, Scott, and Trek
PowerControl VI featuresWirelessSimplified menu navigationIntegrated altitude measurement and storageStorage capacity significantly increased to 1054 hoursNew icons on the clearly legible, high-contrast displayUSB interface allows charging directly through your computer http://www.excelsports.com/image.asp?item=SRM%20FSA%20K-Force%20Wireless%20PowerControl%20VI.jpg
pm sent
