SRM vs. Power tap?
Is there any need to “zero” a powertap if your already getting 0 Watts while coasting. I’ve never zeroed mine because I assumed it was always reading correctly when I check as I’m coasting. Is this correct?
While you’d expect this to be true, at least one person (i.e., Dave Harris) has reported that he’s had occasions when his PowerTap read zero watts when coasting, yet inspection of the ride file demonstrated that it wasn’t properly zeroed.
I could change chainrings on the SRM, but you really need to do a static calibration each time–and you’ll definitely need to re-calibrate after changing the arms.
In my experience neither of things have had a measurable impact upon the slope of the frequency-torque relationship. The only exception to that statement that I’ve personally encountered is when the Torx screws loosened up, such that the crank arm could move ever-so-slightly relative to the powermeter.
You know, I’ve been riding with a PT for 4 years now and I’ve never once had to zero the torque during a ride except during a 2-week period just before I discovered my hub was damaged and had to be sent back to Saris.
My experience is similar to yours, i.e., the auto-zero function seems to help quite a bit in keeping things stable. My point was primarily that just because your PowerTap only ever reads -01/00/01 while the SRM might read 380/390/400, due to the different units and number of significant digits (as well as the much higher angular velocity of the wheel vs. the crank, which tend to magnify the effect of any error in measuring torque on the calculated power output) you shouldn’t assume that this means that the PowerTap is any less susceptible to drift.
Have you used the PT Pro w/ wheel cover? If so, did you find that the weight was an issue?
I ride in the rain a lot. Although the PT hub has made significant advancements (eg introduction of new o-rings) over the last 2 years to deal with weather issues like rain, the computer cradle is suspectible to water buildup so you have to be prepared with some plastic wrap and a rubber band if you know you’re going to be riding in some steady rain.
Do you have one of the old wiring kits (with the ‘prong’ contacts?). I had problems with that one in the rain as well (having a few dropouts). With the newer harnesses (with the ‘dots’ versus the prongs) I’ve had zero issues in the rain–and I’m Seattle as well. The difference is that sitting in a pack in a mid-March bike race is similar to riding your bike in the shower–full blast. No dialetic grease, no plastic baggy/rubber bands, etc. I’ve had no dropouts (and I’m not alone in this).
Maybe the PT gods just like me since I always say nice things about the PT on any online forum…
I have the new one on both of my bikes and I’ve also had the problem with water buildup in the cradle on both bikes. Mind you, it doesn’t happen often but it does happen. All I have to do is dismount the computer wipe or blow the water out and then remount the computer and it works fine.
Thanks, Chris
