I just ordered a new SRM. Question about the PC7 head unit.
Does any heart rate strap work?
If so which HR strap do you suggest?
Thanks for your help!
I use the one that came with the PC7… Suunto…
No issues.
Oh great, I didnt know it came with one! Thanks!
FYI, the strap you will get is an ANT strap, NOT ANT+. It will not be picked up by a Garmin as the Garmin requires ANT+. Same thing with the quick release skewer speed sensor. It’s only ANT, not ANT+.
Not that it matters for use with the PC7, but if you try and use a Garmin, you won’t see your HR on it or the speed if you use the skewer sensor.
FYI,the sensor that mounts on the fork blade IS ANT+.
Confused? ![]()
