SRM on a P3
Has anyone wired a P3 with the SRM kit?
The frame shape makes it impossible to use cable ties for the crank sensor.
Maybe 2 way tape…any ideas?
I made it work on my Aegis T2 (which the P3 was copied from :wink: ). Don’t even bother with cable ties. There’s no way to get them to work. Use lots of electrical tape. There’s an outside chance the SRM Mtb sensor might work better – let me know if you try it.
Oh… and don’t forget, you gotta do it when the crank is off.
hope that helps, Jens
I have set up many aero bikes with an srm- here is my recipe.
1.) Remove crank- note relative position of sensor in relation to bb shell on a regular bike.
2.) attach sensor to frame with adhesive backed velcro instead of rubber ban or ties. On side on frame- on side on back of sensor base. This allow you to be able to move the sensor round slightly if you need to for best pick-up.
reinstall crank and check function.
Good luck,
John H.
