So, I noticed that my SRAM TT900 bar end shifters were having a difficult time holding gears with a tendency of slipping to easier gears (multiple gears down) if it was just slightly bumped. It was rideable but very annoying. The shifter has been very light-action for quite awhile - not nearly as firm as the pair I had on my bike last year. I had just changed the cables out and installed the new PTFE Shimano Dura Ace cables, so I thought the lighter action was due to less cable friction. (The new D/A cables are very nice - highly recommended.) However, I took the shifter off the bar and removed the red face plate and found TWO of the three springs were broken. The light action and inability to hold gears was apparently due to the broken springs. I’m guessing that in the beginning only one spring was broken, and it worked well, but when the second spring broke, the single spring just couldn’t provide the resistance to counteract the rear derail. spring, perhaps magnified by less cable friction. (The bike is a specialized transition, which has full length housing from shifter to derailuer, so there is definitely some cable friction.)
My question is has anyone else experienced this?
I assume SRAM will warranty it since it is less than a year old.
Sorry for digging up an old post, but i seem to be having similar problems. My rear shifter would slip to a bigger cog when in the two largest cogs when hitting a small bump. After just replacing the rather grungy cables, it will now ghost shift as much as 3 or 4 cogs while just easy spinning with the bike in the trainer. The old cables mush have been providing some of the friction that the SRAM TT shifters should be providing.
SRAM TT bar end shifters are remarkably crappy for the amount they charge. One broke on me and I took it apart to attempt to fix it and was amazed at how inconsequential the spring that broke was - it was much thinner than a paperclip. I switched to Ultegra. When mine broke, I found some blog by some guy who was able to fix his, mine was too far gone for his repair method. http://chamoischronicles.blogspot.com/2011/01/sram-r2c-tt-shifter-problems-and.html
Unfortunately, I’m out of warranty. I’m seriously considering pairing up a set of the new Campy 10 spd R2C shifters with my sram red rear derailleur. I’m running Campy 10 spd shifters and Sram rear derailleur on my road bike and it works pretty well.
Bar end shifters don’t really need a spring except to provide “feel” to the indexing points (i.e the click that you hear/feel). The derailleur spring creates all the cable tension.
Same deal with your brakes except the cable essentially is untensioned without the brakes being activated (and cables don’t “push” so well), so it’s nice to have a return spring in the lever to keep it from rattling.
All 3 springs were broken in my rear TT500 bar end shifter. The moment that I would let go of the shifter, it would spring back into the heaviest gear. I looked up “shifter spring kit rear” on ebay (listed in the SRAM parts catalog as part 11.7015.036.000). An option to purchase the springs only came up for $10. I purchased, received, installed, and my shifter is working like new. My LBS also called SRAM and they were going to send them the springs free of charge (haven’t heard back from them). Purchasing on my own was my back up plan.
