Anyone know if the front SRAM TT500 shifter is rebuildable? Mine will not hold a gear…hit a bump, it shifts on its own. If the road is ruff, it shifts. Or is there a way to adjust it. It is about 3 years old and worked fine until rescently.
Those shifters use 3 internal springs. I’ve seen 2 of them break at once, so all 3 may have broken in yours. If this is the case, you have two options
- If its under warranty, SRAM will send you a new one.
- If not, have your LBS order 3 Campy barend shifter springs. Its the exact same spring used in the tt 500. Simple enough for you or your mechanic to install.
Hope this helps
Thanks…will check that out.
Frank wanted to again thank you. The info was spot on.3 springs under $10 and 5 minutes of my time and good as new!
That was fast! Glad I could help.
