SRAM Shifter Question
Laurens from Leap was super responsive to my questions about my Canyon base bar overnight - it has a slight taper around 73mm, but we think the 24.5 will fit with some heating. I ordered from PowerMeterCity in the US. I also ordered the other two grip options (fastTTT and drag2zero) in case the leap components ones don’t work and I will deal with selling them/giving them away. I want to get this over with and I have already spent enough $$ to make this swap happen anyhow. All my other parts should be here this week.
I have used the Leap for about 2yrs, but with a change in position, the straight blip was making the hand uncomfortable, recently tried these https://www.aliexpress.com/item/1005012893848424.html?spm=a2g0o.order_list.order_list_main.4.65e31802GIQDSO I can rest my thumb on the flatter top and quite impressed with the quality of product
That pair from aliexpress look perfect. Thinking I will go with those, and the drag2zeo grips for the base bar.
Some electronic shifting boner fuel right here
Lol, ‘boner fuel’ on the way from Lordgun…. :slight_smile:
nice. early xmas for both of you. enjoy the new parts!
Nice!
I am also 50/37 Chain Ring Gang. I did go with a 10-36 cassette, which I am still a little unsure about. I ran 52/36 and 11-34 on my 11 speed Shimano setup for both Nice 70.3 WC and Ironman Portugal. Both unnecessary, but I really appreciated having the ability to spin more during the steeper climbing. I am sort of in the 4-4.2w/kg range.
My dance card next year is Punta Del Este 70,3 (basically flat), Aix-en-Provence 70.3 (not so flat), Mont Tremblant (not flat, but will probably drop/defer), Ironman Lake Placid (not flat), and Ironman Portugal Again (not flat and some flat)
I’ve been using 50/34 with a 11-30 cassette. Courses like Placid are the ones I need an easier gear for. I ordered the 10-30 red cassette. I know I’ll basically lose the equivalent of one easy gear in the back, hopefully be OK. Worst case I switch to a 10-33..
my road bike is a 50/37 with a 10-33. i find that to be plenty of range for the climbs here in the hudson valley/catskills. for flat/rolling, i go with a 10-28 because i like the 1 tooth jumps from 10-17. the 10-36 will get up everything.
tri bike is a 1x. 10-36 out back and i switch between a 50 and 52 up front. i’ll swap in the 10-28 for flatter courses.
I definitely think I have too much range for the power output I can generate - even in a full. But, my current preference is higher bail out cadence as compared to tighter steps. During that one long ass Nice climb I probably could have used just the 52, but it was nice having the smaller ring and the wider cassette to “do something different.”
I got it all bench tested today and in sequential mode - which is what I plan to use - the system gives me 14 total “gears”. Major upgrade over my aerobar only mechanical shifting I have been using since I got into all this nonsense.
This is overall a good 46th birthday gift to myself. Beats the hell out of the colonoscopy I scheduled for Dec. 14 (9 days before birthday). What a time to be alive!
You will probably use all those gears in Aix en Provence. There is a nasty section at the foot of the last climb :wink:
The day is come for this marriage to be consummated.
I have all three options for the grips - Leap, Drag2Zero, and Fast TTT. After looking at them, I am having the shop try the Drag2Zero two piece first just based on preference. Then if that doesn’t work, Leap. And if that won’t work Fast TTT.
There is a minor flare on my bars (Canyon H30) that comes in right at the wrong spot. Leap seemed confident what I ordered would work.
I will let people know how all that goes. Should have whip back tomorrow afternoon. Also, got sweet talked into flying home and doing a Daytona Clash race with a high school buddy, so that will be the first outside test of all this, even though its completely flat.
If anyone is having trouble with the Leap shifters rotating a bit, I added a super thin layer of electrical tape on the bar under the shifter grip to help with this. Leap recommended me to use packing tape or wheel tape but I did not have any on hand.
I decided to go with the drag2zero grips as well. Will be a while before I can try them. Pretty expensive for a couple small pieces of plastic. After shipping and a little import tax, was like $170 Cad….
This whole thing is expensive. But, it is cheaper than a new bike. I don’t want to start over with a new dance partner. And, I am extremely tired of the aerobar only shifting. So I think we both made the right decision here.
I about lost my mind during my full in Portugal. The whole “slam the FD and then the cassette” with one hand on a climb or technical section is a massive pain in the ass. Let’s hope it all works out. Triathlon - the infinite experiment. :clown_face: :globe_showing_europe_africa:
I attached my blips to the basebar with the plastic clips they come with and some electrical tape. I have the leap buttons.
It’s ugly, cheap, and has worked fine.
I may 3d print a holder that goes on the bar to get rid of the tape.
