SRAM Force Gearhead question
I’m trying to remove a set of Force cranks from a frame, and my standard puller won’t work. The thread ID in the crank arm is significantly larger than what the puller usually threads into, AND the spline of the crank arm appears to overlap the face of the bottom bracket spindle, so even if my puller could thread into the crank arm, I’m not sure it would do anything as it appears as it would just pull against the arm itself rather than the face of the spindle as designed. Any ideas? Is there a special tool for this job I’m missing? Thanks.
You don’t need a puller. Just turn the bolt in the center. The arm will come off. (It may take a shit ton of effort to do so as the torque spec for tightening the bolt is absurd)
Forgive my ignorance, but what bolt? I can see straight through the bottom bracket spindle and out the other side. I’ve already removed the dust cap and fixing bolt, but the left crank arm is still stuck on the spindle (external bottom bracket). Thanks.
Check out their website. They have an awesome step by step video under their service section.
Basically, the 8mm bolt you can see on the non-driveside is what is holding your crank together and the 16mm nut you can see is a dust cap that also makes the 8mm bolt a self-extracting bolt. So all you have to do is back that 8mm bolt out, it will hit the 16mm dust cap, and will start pulling the non-driveside arm off (this will take considerable force). Once that are is off, just pull on the driveside crank arm or the spider and it should slide right out.
See the dude’s response. Basically, put the cap and bolt back on the left arm, then turn the bolt …the arm will come off.
That all makes sense. Thanks everyone. I guess I got ahead of myself in removing the fixing bolt and dust cap, which you normally do in an ISIS configuration.
