SRAM Chains
Anyone know of any problems going from a
9 spd Dura Ace HG Narrow to a 9 spd SRAM
PC971 or PC991.
Are SRAMs just as compatible with Dura Ace/Ultegra components as HG Narrow Chains?
They work great…
99% of our replacement chains are Sram. I would say they are great.
I replaced my 9sp DA chains with SRAM.
went to SRAM with the quick link, 89R I think, and wouldn’t look back. Less than 5 min from bike to degreaser and no pins to press back into place and pinched links when finished. 4 years, thousands of miles and a few chains. No cracks from using Simple green as some have had. I don’t soak them for more that 12 hours.
do it and enjoy the convenience.
Barry
So the quicklink brings up another question.
Has anyone ever used the SRAM quicklink with a Shimano HG Narrow Chain?
No, but spring for the 991 instead of the 971. I have had both and the 991 is just a nicer, more corrosion resistant model.
Chris
I’ve used SRAM quicklinks on shimano 9sp chains before, no problem at all. The SRAM version is slightly different for the 10sp - it’s called the powerlock - and works fine with all 10sp chains.
So, make sure you buy a “powerlock” for 10sp, and a “quicklink” for 9sp.
Ok, so I think I got it.
So SRAM has quicklink, powerlink, and powerlock.
The quicklink and 9 spd powerlink gold are the same cept finish. Either will work with Shimano HG 9 spd Narrows.
Power lock is different and is made the the 10spd srams and will not work with Shimano 9spd or 10spd HG Narrows
Their 10sp link - called the power lock - will work with any 10sp chain on the market. Same for their 9sp stuff.
The PowerLock isn’t supposed to be broken though. It’s just a tool free way to connect the chain so a better choice would be a Wipperman connect for a 10 speed chain.
You can use as many PowerLock links as you want in a chain but SRAM doesn’t recommend you break them to take a chain apart.
