SRAM carbon bar con levers on Duraace?
Can I use the New SRAM 10 speed carbon bar con levers with my Duraace derailluers?,They have a much better appeal and finish than the Shimano ones.
In short no. The front shifter is friction and therefore should work but the rear works on a one to one ratio (and no friction) and won’t work with dura ace.
The SRAM carbon lever does not pivot laterally like the D/A one does. You would never be able to shift…
Related question…
Has anybody setup a bike to run the SRAM shifters (I’m looking particularly at the TT’s, but I assume it would be the same for the normal style), with a SRAM rear derailleur, but with Dura-ace (or any Shimano) cassette/chain?
In theory it sounds like the spacing is the same, but how good will the quality of the shift be? As good as all DA or all SRAM?
I have (except the chain). Works fine. SRAM and DuraAce chains are the same specs.
