I recently swapped my eggbeater pedals for speedplay x1’s, based primariy on recommendations from fellow riders. I was intrigued by the 180 degrees of float these pedals provide, but after using them a short time, I have developed some pain in my right knee. I have a wobble in my right knee when pedaling. I noticed it before with the eggbeaters, but it rarely caused knee pain. Could the total freedom of movement provided by the X1’s exacerbate this problem?
Also, does anyone else have a wobble in their knee, and if so, what exercises are recommended it fix it. I’m pretty sure it is the cause of my knee pain.
Thanks for the feedback.
Were they new cleats? I ask because I experienced a sudden onset of knee pain with these pedals (I purchased new but put tons of mileage on them) as well and finally figured out that it was due to the cleat being worn out and allowing the shoe to wobble (or pitch) left and right. The metal horseshoe spring wore into the plate pretty badly, also the black base plate that the pedal rests on developed some wear as well. As soon as I put new cleats on the pain went away. Check for that if they are not new. In my opinion anything different than what your knee is used to can cause problems. Having a huge float allows your knee to be in many different possible positions when applying pressure. Maybe you should back off and spin for many sessions until you can “retrain” the knee joint for different lines of force.
My experience with my own knees and those of many other customers is that X series pedals can alleviate knee pain if you have it, and cause knee pain if you don’t have it. The Zero series pedals I feel are more appropriate for everyone, knee issues or not. The amount of float as well as the inward and outward movement can be controlled and will stabilize a knee with poor rotational stability.
Sell the X-1s online and get some Zeros, you’ll be able to mimmic the egg beaters in terms of allowable float with them. I’m doing that as we speak.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=7126876585&ssPageName=STRK:MESE:IT
Good Luck.
-SD
does this belong in the classifieds?
