Hi,
Congrats on the new bike.
They are not all interchangeable. Don’t quote me, but i believe speedplay zero’s can’t be used with light action cleats and viceversa.
The speedplay website is plenty informative. I’m sure you can figure it out from there.
Good luck.
actually they are not the same pedals, or the same cleats. I don’t know what’s different about them I just know they aren’t interchangeable, per a sales rep at Speedplay.
no they’re not the same but as someone who also rolls on speedplay, i’m just fired up that SIDI is finally making a speedplay compatible sole!
I’m confused- I’ve been using speedplays on my SIDI Genius 5.5’s for the last year. Have I managed to attach the cleats to an incompatible shoe, or do you just mean you’re glad a factory-supplied adapter is no longer necessary?
even though the Light Action and Zero pedal bodies are slightly different, the Zero cleat will attach to and release from a Light Action pedal body. I only clipped in/out a couple times to test things out, so I’m not sure how it would work as a long-term setup, but the parts definitely fit together.
Note: Light Action pedals are not compatible with Speedplay Zero and X-Series cleats.
Light Action cleats are not compatible with Zero and X-Series pedals.
I know they say they’re not compatible, but the Zero cleat does clip in/out from a Light Action pedal.
of course the cynical view is that it’s harder to sell a brand new set of pedals (at $100+) when you can “upgrade” to the Zero system from the Light Actions by buying a $40 set of cleats.
