Speedplay light -- hard to get into?
I just had a set of Speedplay Light Action pedals installed, with the cleats put on a new pair of shoes.
I’m finding them a bit hard to get into – this has resulted in some left shin smashes.
Is this a matter of fit?
You might have your cleats screwed down too tightly.
I was wondering… thank you for the quick response!
I had this same issue with some zero’s…ended up even calling speedplay about it. If you have never used speedplays like me then you have to wiggle your angle from left to right to get them to snap in. My wifes Lites are the same way and she had me take them off. It took mine about 2-3 weeks before they were smooth on the snapin.
AS with any new equipment it’s important to read the installation instructions. With Speedplays there are a couple things to be aware of:
  1. The radius of the cleat adapters- the two little wedges at the front and back of the cleat- need to match the radius of the sole of your shoe. It is different from one shoe manufacturer to another. Speedplay cleats depend on the cleat being flat- it can’t be bent to conform to the radius of the outsole of the shoe. If it is, you may have problems engaging the system.
  2. There is a specific torque setting for the four small bolts that mount the outer cleat cookie (the anodized alloy section) to the inner (polymer) section. If you over torque these the retention spring does not work correctly since it is held too tightly between the outer and inner cleat layers. These bolts are coated with blue LocTite thread locking compound to keep them tight at relatively low torque. Be sure you didn’t over torque these. This is the most common issue with Speedplay cleat installations.
  3. When the pedals are brand new- the tolerances are very precise. As you clip in and out on both sides the cleats and the pedals seem to “adapt” to one another, perhaps wearing in just a trifle, and work better.
  4. Per Speedplay’s instructions, using a little White Lightening style wax based lubricant can improve the perfromance of the “C” shaped rention springs and facilitate easier rotational movement of the foot on the pedal along with easier entry and release.
I hope those tips help!
Thanks to you both! I think it’s time to do a little unscrew and lube job… The LBS guys are good, but adjustments make sense.
