Specialized Tri Spokes?
I have an opportunity to make a trade for some specialized tri spokes. So my question is are the Specialized Tri spokes the same as Hed Tri spokes? Is the shape the same? I would assume they may be heavier.
Very close.Make sure that they use a cassette and not a freewheel.
Cullen
I think HED bought the patent from Specialized. I could be wrong though.
Ed
Any last minute IM tips?
I have a Hed 3 front and a Specialized 3 rear. The carbon is a shade lighter on one and the Hed 3 rear would be a few grams lighter but otherwise they are identical.
Cullen
Right now they are campy i will need to switch to shimano.
Ed
Dont drink yellow water.
The original Specialized trispoke was matte black, and was significantly heavier, I don’t know exactly how much. Later models have the same carbon weave look as the H3 and were lighter. The matte black ones should be worth less.
Cullen
Not very close… Hed’s 3-spoke wheel is more than just an imitation of the old Specialized wheel. It is the old Specialized wheel. Hed bought all the Specialized wheel technology and property developed originally by DuPont. They were never built with freewheels, and have become lighter over the years.
Actually they did have freewheel. Well you can make the front in to a rear wheel by screwing on a freewheel. You can also make it a fixed gear wheel too.
In any case the point is still, make sure the rear wheel has a hub on it. I ride Specialized and they are the same as the HED 3s. Take the sticker off and you wouldn’t know the difference.
You’re right, they didn’t make one but it could be converted. Good point.
Ed in Il,
The Hed 3 Tri Spoke has always had a Shimano hub exclusively. This was the same with Specialized Tri Spoke as well.
If the wheel you are purchasing or trading for has Campy now, it has some form of a conversion cassette on it. All you will have to do to “convert” it will be to take off the Campy conversion cassette and put on your Shimano cassette.
There really is no conversion necessary for you to put a Shimano cassette on a Specialized Tri Spoke wheel. It already has a Shimano hub on it!
That is technically inaccurate. In 1990, my roomate had a Trimble with dual specialized trispokes. The hub was made with a thread on freewheel and you could interchange the axle and use the wheel as a front or rear wheel.
