Spare Part for SRM Harness
On the SRM harness (and the Ergomo too, I think), the sensors are a two-part component, with a mount part that’s fixed to the frame that the actual sensor slides into. Does anyone know where to get the mount part by itself (preferably in the EU), or what the part’s called - I’m pretty sure it must be used in things other than Power Meters!
Thanks
Stuart
Thanks
Stuart
IIRC, the mount to which you refer is made by/shared with Sigmasport computers. If so, you might be able to buy a cheapie model for less than what SRM would charge you for an entire wiring harness.
Another thought: If the above isn’t correct and you can’t find just the part that attaches to the frame, you might just use this as an excuse to buy a rear wheel SRM harness (thus keeping the front of your TT/tribike aerodynamically “clean”).
I think this is what you are looking for?
http://www.competitivecyclist.com/za/CCT?PAGE=BUY_PRODUCT_STANDARD&PRODUCT.ID=3402&CATEGORY.ID=844&MODE=&TFC=TRUE
Shipping is super fast.
Thanks, Andrew, I’ll look into the SigmaSport harness.
Regards
Stuart
That should do the job - just need to check if my bike has a bolt on the bottom bracket (Giant TCR - non-Carbon).
Thanks!
Stuart
