Spacer Math Question
After rroof’s fork experience, I am going to make some adjustments to my set up to include a 2 or 3mm spacer between the stem and the top cap. I have a 10mm under the stem now, so I need to make the spacer math equal out to 10mm total. My question: Is a 2mm + two(2) 3mm under the stem as strong as a 3mm + a 5mm? If not, is it strong enough to be safe?
