Sore Knee
Ok, my situation is this:
Ran a marathon the end of may, felt ok afterwards aside from the usual muscular pains you would expect. Between then and now i have done no running, and been almost exclusivley biking. Have started running again now, with a view to building for a half in a few months time, but i am getting some knee pain while doing it.
I have never had this kind of pain before, feels like a stiffness under my kneecap - as if it could be stretched out, but have had no luck. I am not doing any really big weeks (just 30ish mpw at the mo) and dissapears within an hour of finishing running - is this a case of too much too soon?
Could it be my shoes? I train in a pair of Mizuno Nexus, and have never had any problems with them - my current pair has about 280 miles in them, but they still look in relativley good shape.
Its not something that really worries me at the moment, as I can live with it and run on it, but i would rather be able to walk in the future than not
I’d say two good remedies would be 1) to cut the distance and/or 2) to slow down your pace. See how that goes. I recently started MAF running ( 180 less age adjusted for fitness level to find target heart rate ) and it’s very good. I had a lot of pains - knees, feet, shin splints but MAF slows you right down and allows you to build aerobic muscle fibres which are stronger. Now if I should run on a training day but feel tired or stressed I go for a walk instead…and I feel great. :O)
Regarding your shoes. Take out your insoles and you should be able to see your foot print perfectly. If you can’t then something is wrong. For example if you can’t see your little or big toes ( or only part of your big toe ) then your shoes are too small.
Hope that helps and good luck with the half.
Snip - maybe 30 mpw is more than your “bike ready” body can stand right now. Maybe to back off to something a good bit less than that, plan out the next couple of months at the usual rate of increase you see here and see what that gives you. I’ll bet that it diminishes your distress. If that doesn’t do it, perhaps a visit to your local shoe guy/gal for an eval of your shoes, gait, etc…where you are now, may also be of benefit. Good luck.
Was interested to read your post as I had similar symptoms over the last year - sore knee and only hurt when I run and pain went away quite quickly when the run was finished. I agonized over shoes and gait and all the posts about weak muscle groups and tendons causing pain from strength imbalances.
Went and saw some really good folks and it was a bit of a head scratcher. Then they recommended that I get an MRI. So, I got one and got the result, “…extensive full thickness fissuring involving the retropatellar cartilage…” in the patellofemoral joint compartment. I’m told this is osteoarthritis and that my knee is essentially screwed. I only started enjoyin running in the last year too.
I’m hoping your knee(s) are in way better shape than that. I’m hoping it is your shoes! Keep us posted on what works for you on this.
Paul - I have lots of patients with the same problem as you and I wouldn’t be so quick to yield to it. I arthroscoped one a couple years ago who, this year, ran the Army Ten Miler with his son. So, ask around and see what you can find out. Good luck.
I believe this is the most polite and educated **HTFU **I’ve ever read on Slowtitch.
One muscle imbalance that is commonly overlooked that will cause that pain (some patellar tendonitis) is if your hamstrings are too strong and not proportionate in strength to your quads (or visa versa). Depending on your bike riding style you could be pulling with your hamstrings through your pedal stroke (giving some great bike speed) but not using your quads enough to build them strong enough to hold all the pieces of the knee together in the right way. Then all the impact of the running and using those muscles even more are giving the knee some grief!
Try some quad strength training!
Cheers for the replies guys.
With regards to the arthritis, im only 22, is it likley that it could be affecting me?
I have ran in the same brand of shoe, with the same gait and footstrike for a while, so i don’t think it could be anything to do with that.
I’m hoping its just me jumping back into 30mpw running after doing nothing but biking that is causing it. Went hiking yesterday and my knee was complaining enough that i knew about it, but not enough that it really bothered me. Ditched the long run today and am going to cut back on the milage next week. New pair of shoes on order too, as i said, my current ones have only done 280 miles, but better safe than sorry i guess.
Sally - you are too kind.
First - thanks for the helpful reply John (I agree with what Sally said also) - I was incredibly disappointed to think that I wouldn’t be able to complete an Ironman without more or less walking the run portion. It’s good to know that there are other potential options out there. Is there a good place to read more on that procedure?
Parsnip - I’d follow John’s advice in terms of getting some additional opinions on what’s going on. no idear if you have arthritis, but my understanding is that you aggravate joints many ways at many ages. I’ve had sore joints since a motorcycle accident at age 19. Except for my knee, I find that Joint XL works really well for keeping joints healthy. ** I don’t work for Joint XL in any way, but had the good fortune of having my friend Hillar introduce me to it.** It’s the only thing that keeps this body from constant ache. If you’re not allergic to shellfish, you might want to try it.
Otherwise - I’m sure that there are lots of folks that can provide much much better advice than I on the finer points of running and when to ramp up and when to back off.
all the best!
