Some top swimmers with "poor" breathing technique
When watching NBC’s Kona coverage, I noticed that a number of pros (including Faris) are rapid breathers. That is, they breath every two strokes on the same side. I’ve seen Dede Greisbauer do the same thing. Even at the Atlanta Olympics in the 1500 meters (someone posted the video on another thread) you can see one of the competitors doing the same thing.
I guess it’s one of those things like an aero bike bottle - it’s nice if you can get it, but it pales in comparison to having a big enough engine. Me, I’m going to stop worrying about my swim breathing (tennis ball exercises, etc.) and JFS. I’ll still do drills to improve body position, catch, etc. but no more worrying about the breathing.
If you read the current thinkings, the majority of it recommends more breathing for distance events. Breathing discipline is more important in very short races where the difference between 1st and 5th place may be well under 1 sec.
I consider myself a fairly good swimmer (obviously not on the same level as Faris or any of the Olympic swimmers), but have been swimming since I was 6. I only breath to one side and 90% of the time, I breath every 2. Yes it’s not ideal and I certainly don’t have a perfect stroke, but it’s a bad habit that I can’t break. Even while in college I noticed several of the distance swimmers that also only breath to one side. I think body position, hip rotation, etc. are more important than how you breath.
Hmmmmmm…
I think doug might scold you a bit, but good luck with that.
I like the idea about breath management and getting enough air. Generally, I breath every 3 or 5 strokes (alternating sides) and occasionally I feel starved for air - especially coming out of a flip turn when I’m in the pool.
Your stroke will be much better balanced if you alternate breaths (your pull will be more equal) - wish I could do it! My recommendation would be to stay with the breathing every 3 or 5 - you will get used to it and your lungs will probably increase in capacity over time.
As a swim coach, I can tell you that the two things we mainly focus on in freestyle especially is effeciency and rhythm. If you dont have both of those, you are in for a world of hurt. Some swimmers can be effecient breathing every stroke (Michael Phelps for example breaths the way you describe as well.)
The biggest reason we stress these with most swimmers is that they MUST have an even stroke. The problem with breathing to one side for many people is that typically your stroke does not remain even and can cause undue stress on your shoulders. In this case, usually the opposite arm from which you breathe to will have a significantly shorter stroke. This causes you to pull straight down from the top of the stroke in the place where you are supposed to be sculling out - the top part of the “s”. I have found that most of the swimmers I work with that do have shoulder problems all mainly breathe to one side -whether its every stroke or not. THat is why the younger age group coaches really stress alternate breathing.
Swimming like many things is very individual. You must find what is right for you. GO find the underwater or overwater video from any Finals Heat in the olympics in any stroke and you will see 8 different people with 8 very different strokes. Swimming is definately not a cookie cutter sport. Everyone is different.
If a swimmer isn’t comfortable bi-lateral breathing, and their coach doesn’t get on them too much, they will not do it. Therefore, most swimmers don’t do it. It’s not because bi-lateral breathing isn’t faster.
What happens then is that the swimmer builds up their muscle on the side to which they breathe, and then it is really really uncomfortable to breathe to the other side.
An easy way to notice if a swimmer is stronger on one arm than the other (as mentioned by klorene, typically because they breathe to only one side) is that they will tend to gallop and stroke will be very uneven.
You make a good point. I have found that often, watching the best in the world is not an effective way to learn. Dede and Faris are just a couple in a handfull of people lucky enough to be able to RACE an IM. I would also argue that both of them have spent years of their lives training and racing (swimming) that way and thus have become effecient at breathing more rapidly. That said, I have not seen extended viewing time of either, in competition. It may be possible that what little we have seen, is not actually what is happening in the long haul.
I completely disagree with breathing being more critical in shorter races, and to stop working on your breathing is not the smartest move either. If anything, breath quality is even MORE critical over an IM than say, 100 meters. Breath quality is a critical component of physical activity and is even more effective at guaging the “effort” level. I agree to JFS. So do that. Work on your breathing outside of the pool, so you can notice how ineffective it is IN the pool.
daved
I am worried about my breathing because I do it wrong and create a lot of drag. The less I breath the less drag correct? By breathing correctly I guess I can breath more often, like every two.
While I don’t think I could ever go back to breathing on the same side (I’ve been an alternate stroke breather for years) I am going to stop worrying about trying to take 5 strokes per breath rather than 3.
Breathing patterns in a race are generally different from training. You don’t want to short yourself on air, especially that early in the race. I don’t train breathing every stroke but generally I do race that way.
Besides evening out your stoke, bi-lateral breathing also helps to keep you going straight. When I breath ever2 strokes on the right side, I drift towards the right and have to make numerous corrections in course and more sightings, which are very inefficient. Now I try and just stick to alternating every 3, and if I feel winded in a race, use the every 2 as a recovery for a bit.
I do this as well. Like someone else, I’m not an elite swimmer, but started swimming competitively when i was a kid (6 y/o) and am usually FOP in most triathlons. When I swim in a pool, I usually alternate sides every lap.
Fairly common amongst elite swimmers both in the pool and in open water for the longer distance events.
1500 - Grant Hackett
I don’t think that very many competitive swimmers breath bilaterally all of the time during races. Especially not in any race over 100 yards where getting as much air as possible is extremely important. Even the sprinters that don’t breathe very much in the 100 or at all in the 50 still tend to breath on the same side every time they breathe. If you swim SCY (and most US swimmers do a lot of that), you breath bilaterally and you don’t breath until at least your second stroke off of the wall, you are getting very few breaths per lap. This is going to affect your race a lot more than any marginal increase in form that comes from breathing bilaterally.
It’s a nice thing to be able to breathe on both sides so you can look around more or to avoid the sun shining right in your eyes if you are swimming open water. It might help a beginning or intermediate swimmer to balance out your stroke to breath bilaterally. But, if you want to maximize your speed and endurance, it’s best to breath every other stroke.
you must be watching different videos from me. i have watched a lot of them. nearly all the swimmers in the finals of the 800 and the 1500 of recent olympics breathe every stroke (i.e., same side, one breath per full stroke cycle).
It actually means the opposite : they have excellent breathing technique that allows them to lose the least efficiency while breathing, and therefore they can afford to do it frequently, which for distance events is the best.
no way. if you are training right, the swim sets you do at high intensity should be swum just like you race. and you should breathe with the same technique too.
