Soloist sizing help...again :(
I know, I know…I posted before and received a lot of good comments but… now a shop told me they usually size down with Cervelo…so…
I am about to order a Soloist Team and I am not 100% sure about size…again.
My height is 6’1" or 182.88cm
Inseam is 35" (book in crotch method) or 88.90cm
Pant inseam is a 33/34.
Arm length - 26.5 or 10.43cm (shoulder to thumb).
I believe a 56 would work with a 110 or 120 stem and a 58 with a 100 or 110 stem.
I like a lot of drop (European style) and a flat stem. I find I have the flexibility to ride this way and enjoy riding in the drops.
Local shop has the 56 but I could not compare it to a 58 since they did not have it in stock.
Any thoughts?
Thanks!
I would think a 58. Check with your local shop and if they have any Cervelo road bikes in a 58 on hand check your sizing, geometry is the same on all road bikes.
Thanks…no 58’s in stock so I couldn’t compare.
I am 5’9" - 5’10" and I am riding a 54 Soloist (use to ride a 54 r2.5). Use to ride a 55 DeRosa for reference
Any thoughts?
Thanks!
i’m a hair under 5’10" and ride a 56 soloist. granted i’m pretty leggy but the top tube matters more and i sometimes feel like maybe i could have gone with the 54. love that damn bike though!
I’m 6ft 34 inseam
ride a 56 carbon soloist
tried a 54 but the seatpost was almost maxed out
Is that your pant inseam when you buy jeans or measurement via a book. Are you in an aggressive position? Could you have gone to a 58? Sounds like a 56 might work for me.
Thanks.
I’m 6’1’’ with a 32.5 inch inseam (book method) and I ride a 58 with a 90mm stem. It fits pretty well, and I have about 10 cm drop from seat to handlebars. I do have the seat up about as far as it will go without switching it to the forward position, however. If you get the 56 you’ll show a lot of seatpost, but it will probably give you more flexibility on stems and where along the rails you put your seat.
Ok…that gives me a better point of reference…thanks…
It may be too late, but if you don’t trust what the shop is telling you, find a new shop. This is too big a purchase to be having doubts just as you place your order.
I know…I am leaning towards ordering it online through a very reputable dealer. They allow returns on size issues (hassle free) but I just don’t feel like ordering it a returning it etc…
I am leaning towards the 56 and feel I know fit pretty well but Cervelo is a bit different with geometry and wanted to see if any others were faced with a similar dilemma. Thanks.
Do you have a current bike that fits you well which you could measure? If so, I’ll tell you the easy way of figuring this out :wink:
No…currently riding a Scott Plasma in a L(56). Fit is perfect but since it is a tri-bike and I am riding steep it is difficult to move the numbers over to a traditional road bike. If I am incorrect in my assumptions I am all ears :). Thanks.
Dang. If you had a road bike, I would’ve told you to just measure the stack and reach and compare to the numbers on the Cervelo geometry chart…oh well.
That said, I’m 5’10 - 5’11 (Dammit! I keep SHRINKING!) and have a 33.5" inseam (crotch to floor). I’ve got a 56 Soloist and run a 110 stem…but, I also run a decent amount of drop (sounds like you do too).
I’m guessing a 58 is more your size.
I have a soloist SL and a SOloist team (alloy) for training. i’m 6 feet. as you know, i ride a ML giant which fit perfectly, a 57 top tube. the 56 soloist is a smidgeon smaller. i didnt swap stem but it feels just fine, but definately right on the verge of ‘smallish’. i like them small. i do a lot of racing, and crits and road races and throw the bike around a lot. smaller=lighter weight. not sure how that plays out with a Tri position, but if i could sneak another 1/2cm to 1cm on the top tube, i would.
i’m 6 feet, 32 in inseam, pretty average proportions, nothing exceptional.
to me, at 6’1, i think u have a tough choice. a 58 with a shorter stem will be great, but i always recommend going with the smallest size you can fit properly. but that leaves litle room for goof. ideally , you dont want at 130mm stem ona 56cm. you’d might rather have a 58cm bike with a 110stem for perfect steering.
The giants are just that little bit bigger. the ML fitme perfect.
Thanks…I appreciate your input.
Thanks. The problem I am facing is that I have a short torso. The 56 I looked at had a 120 and it was pretty close. Appreciate your comments and suggestions.
I remember your first thread, you and I are nearly the exact size. My book-to-crotch inseam is 36.75 inches (93.3 cm) and i’m 6-1 and three quarters tall (long legs & short torso.) I had a 58 soloist team and I now ride a 58 SLC SL, both with a 110 stem. I cant remember the seat tube difference between the 56 & 58 frames but i’d guess you’d see some serious lateral motion on the post when you pedal if you got the 56. I feel like I’m showing too much post on the 58 as it is. here is a pic of the 58cm Team before I sold it for reference… lots of post & zero spacers. I havent taken good pics of the SL yet but its set up exactly the same except I got a neg-17 stem from FSA that puts the stem almost parallel to the ground, so slightly more drop.
http://i10.tinypic.com/4qfa6nc.jpg
Yes…I think the 58 may be the way to go at this point. Thanks!
