I recently moved from Atlanta to London and my bike arrived with the seatpost jammed so hard into the frame, it simply won’t come out. Assuming that there is a way to get it out (not so sure about this), is the frame integrity in question since it’s a carbon frame (Cervelo soloist carbon) - should i be demanding a new bike from the movers?
Good question G, I would suggest taking it to your nearesr Cervelo dealer and getting them to inspect it. I hope for your sake it is just a case of freeing it, best of luck.
Welcome to England, it will get better from here on ![]()
This is not uncommon when you have carbon to carbon. do not try and force it out yourself. A bike shop can wedge it out by securing the bike and using the seat as a lever to get it out. Good luck.
Mine slid down a bit and was jammed.
I googled it, and it was pretty common.
Secure the bike and tap up on the seat, and it should come loose after a few mild taps.
thanks all for the help, i’ll take it in and give see how it goes.
