Soloist and seat tilt issues
It’s winter, and that means trainer miles. It’s also my cue to switch the seat head and bolt on the aero bars on my Soloist.
My issue is pretty straightforward:
What do I need to do to get the seat angled down in the forward position? I seem to have maxed out the adjustable angle…I could raise the nose up as far as I like, but I can’t get it to go down. When the seatpost head was flipped the other way, I solved this issue by hand-grinding down the bolt to shorten it, because it was bottoming out. I can’t for the life of me figure out the equivalent when the seat is in the other position…
My sensitive bits thank you in advance. I need to get the nose angled a few degrees lower, help me out here.
it’s not easy… you may have to file down one of the screws some.
great bikes with horrible seat clamps, i just don’t get it.
From what I can tell, neither screw is bottoming out anywhere. The actual clamp mechanism seems to have run out of room to rotate. Surely I’m not the only one with this problem?
Blatant plea for help. Gerard? Anyone?
It was impossible for me to get enough torque to turn the screw with my fingers. I had to use some needle nose pliers to turn the screw.
Other way around. The hand-tighten is all the way loose, the other end is tightened all the way down, and the nose is still too high. I’m riding in the forward position, remember.
Oops sorry, I guess I misunderstood. It does seem like that seatpost needs more range of adjustment. Does anyone know if the newer models have more range? Mine is a 2005 I think.
I had to grind a couple tenths of a centimeter off of the knurl bolt on my '05 Soloist to get the OEM Selle SLR saddle level. The bolt is a bit long. Saddle choice also makes a difference. The SLR seemed to tilt a bit more nose high from its rails than other saddles.
I did the same thing, when in the rearward position. I ground off maybe a quarter inch to get the seat level on the SLR.
With the seat reversed, however, I do not seem to be bottoming out. There doesn’t seem to be enough adjustability in the clamp mechanism itself to get the seat to level. Again, maybe my description is lacking, but the problem does not seem to be bolt length. If the seattube were a steeper angle in the first place, ala the P2K, it would be angled nose-down, but the Soloist is built with a more laid-back seattube, so I’m stuck with the nose raised above the level. Still looking for a fix.
Hi Alpern,
I should be able to help. Give me a call at 866 Cervelo x232 and we will get you going again.
Before you call Chris at Cervelo, check this. Try rotating the upper clamp of the post 180 degrees. To be more clear, take the clamp apart and turn the upper portion around so the hole that had the thumb adjuster bolt in it now has the other nut in it. I’ve seen this clamp reversed before and suffer from this problem.
I’ll give that a try this evening when I get home - thanks. Hopefully this will do the trick…
