Sold. (78)
If you are a believer in proportial length crankarms and you want to try some out inexpensively, this crankset is for you. I normally use 190mm and bought these off ST, but after a couple of months have decided the 195 length is just a little too long for me. My inseam is 34.5 so a good range for someone who might use these well is 35 to 36 inches. If you are even taller and presently use the normal run of the mill 175mm then these would also benefit you.
$200. No chainrings included, though I can include a set of Dura Ace TT rings 54x42 for another $25. Money order is preferable.
130mm bolt circle
Square taper bottom bracket. Price will include the required 113mm bottom bracket.
Brand is High Sierra Cycle Center. They look like this:
http://www.hscycle.com/Pages/customcrankset.html
I have no idea on the age; I’ve had them for about three months and I recieved the impression the original owner used them a few times and then his doctor told them they were bad for him or some such idiocy.
Chad
Make? How old?
Additional information provided above.
I want these things bad, but am low on cash right now.
argh!!
david
