2009 Colnago Flight TT size large (58cm+) (I bought the frame in August of 2010) It has been on the road approximately ten times and on the trainer roughly ten times as I was mostly riding my cross and MTBs. The only blemish I see on the frame is a paint chip on the head tube (pictured below) that I sealed with clear nail polish.
Bontrager XXX Lite carbon base aerobars (the pads adjust in/out four positions and fore/aft three positions). I bought these bars used.
Oval Concept extensions
SRAM carbon shifters.
Rolf Vector Comp wheels
Hutchinson Carbon Comp tires in good condition
Bontrager X Race alloy brake levers.
Bontrager RL 100mm stem.
30mm left on the steerer tube after the stem is attached (3 spacers).
Colnago aero fork…carbon steerer tube.
Carbon water bottle cage.
Shimano 105 brakes.
SRAM Red cranks 53/39
SRAM Red front derailleur
SRAM Red rear derailleur
Two seatposts (a triathlon one and a TT one…changes seat tube angle from 73.5 to 76.5 degrees…if you slam the seat forward you should be able to get much steeper see the geometry chart below for the “Carbon Flight Triathlon”
Fizik Arione Tri saddle with Manganese rails.
No pedals.
Top Tube (center-center) effectively 56cm
Seat Tube (center-center) 50cm
Seat Tube (center-top of seat post collar) 58.4cm
Head Tube 13.7cm
$1650 for bike. Paypal only to lower 48 or local pickup in Rochester, NY area for $1600. A steal!!!
