It snapped at the shaft ~ just about dead center of the BB. The crankset was bought and installed in March. A new to me LBS mechanic installed it. Is it possible to so poorly install a crank that such a thing could happen? A mechanic at the race said he had never seen such a thing. I looked for warranty info on the Campy website but nothing to be found. Will this be covered? I bought it from Bike Barn but no customer service available.
Pics? Not sure exactly how the UT crank is put togwether, but isn’t it “prebroke” in the center of the axle? do you mean the bolt holding both sides together broke?
Styrrell
Are you saying the Hirth fitting broke or the bolt?
My wrench skills are on par with my camera skills. In thinking this through I started hearing a click last week or perhaps the week before. It sounded like a magnet hitting the speed sensor each time around but that was not it. It was only discernible during no wind and no traffic conditions. The picture does not show it but the fx is past the threaded portion of the bolt.
Bump
Looks like the bolt broke. I assume a shop can remove the two pieces and replace the bolt. My guess is that the bolt wasn’t tight or came loose. That would allow the two sides of the crank to flex, which would effectively bend the bolt with every pedal stroke.
make sure the threads on the crank are fine and the mating teeth on the axle are in good shape, replace the bolt and recheck for tightness every once in a while.
Styrrell
That “clicking” sound was the joint in the crank coming loose, which happens with these cranks sometimes, even when they are installed correctly.
If you don’t re-tighten the bolt connecting the two halves of the cranks when they loosen, you will break the connecting bolt, destroy the teeth on the hirth joint, or both.
Unfortunately, that sound that you ignored was also the sound of your warranty going out the window. The cranks broke due to your not re-tightening the bolt when it loosened. If you had investigated the noise when it first occurred, this wouldn’t have happened.
This is an unfortunate occurrence, but I have seen it before, and I have seen it happen with cranks that I know for a fact have been properly installed, to the correct torque spec, on frames that have been faced and chased to the correct spec. It’s more common on frames that haven’t been faced and chased or are out of spec on the BB width.
This isn’t the fault of your LBS, so you might want to step away from the “Is it possible to so poorly install…” nonsense, and accept that when a mysterious clicking noise crops up on your bike, and you don’t do anything about it for a couple of weeks, and something breaks, the fault is yours and yours alone.
If the Hirth joint isn’t damaged, this is a pretty easy repair - you simply need to have the connecting bolt removed and replaced. If the joint is hosed, you’re going to be buying a new set of cranks.
bad design? I know a couple of folks who’ve broken those with less than a year of use
Engineering is not my area but if the crank tolerance on these are such that a faint clicking noise can morph into a broken crank in no more than 150 miles or as little as 75 miles which is what we are talking about I’m going back to Shimano. I have less than 1,000 miles on these.
I know a couple of folks who have broken every crank made…since square taper that is…
It was the connecting bolt. It was likely not snugged down to spec when installed. Lesson learned.
Truth be told, that is a stupid bolt that require a torque that most shops never see. Not sure why they didnt use something more common, and not hollow (say a standard crank bolt from square taper for instance).
I was surprised to see a hollow bolt, seems like an odd place to save a few grams. A solid bolt probably would give us slow learners a bit more time to figure out what’s sqeeking. If you know the toque spec pass it on please. My LBS went on a search this am to locate a bolt. No joy yet.
Get a new LBS.
The spec is printed right on the bolt in very clear black letters…42Nm.
"Engineering is not my area but if the crank tolerance on these are such that a faint clicking noise can morph into a broken crank in no more than 150 miles or as little as 75 miles which is what we are talking about I’m going back to Shimano. I have less than 1,000 miles on these. "
Uhhh… yeah. Still looking to blame someone else, I see.
If you ignored the same problem on a Shimano crank, you would have the same result - broken crank. I have actually seen many more Shimano cranks destroyed by riders ignoring the warning signs of a loose crank arm than I have seen Campy. In fact, if you ignore a loose shimano crank arm, you almost invariably destroy the crank. With the Campy, most of the time you merely need to replace the bolt.
" I know a couple of folks who have broken every crank made…since square taper that is… "
C’mon, Chip… there are lots of good reasons to complain about the “modern” crank standards, but you’ve been around long enough to know that there were lots of broken cranks and BB spindles in the square taper days. In fact, I would go so far as to say that we don’t see nearly as many broken BB spindles now as we did then, that even if we see as many (or more) crank failures now, they are rarely catastrophic, and that cranks - in general - are far better now than they were then…
…of course, I still spend time in a shop, so my “back in the day” fantasies are subject to a greater dose of reality than those of certain people… :0)
This guy had problems with the Hirth joint:
http://roguemechanic.typepad.com/roguemechanic/2008/09/campagnolo-ul-1.html
I can’t really comment on this joint but it does on the surface appear to be a high tolerance complex design. I love the simple and reliable way that shimano designed their outboard BB cranks (at least Ultegra SL). Simple and strong.
