There are some new options out there. FINIS, FORM, HoloSport, Speedo, edit not magic5 lol…I’m having a hard time finding good reviews/comparisons. Does anyone have experience with multiple platforms that can share experiences. Speedo might be the only one that doesn’t offer a HUD so mid-swim tweaks aren’t going to happen with those but I believe the rest do. Thoughts/opinions?
I have almost 900k yards on my form swim googles. I recently replaced the seals for the 2nd time which are cheap and easy to replace. Never had any issues with them. My goal in 1 million yards before I buy another pair.
+1 on the durability of these goggles! I still have the first version
I had the first version for the Form goggles and they were easily the most uncomfortable goggles I’ve ever used; they leaked like crazy and the only way I could make them stop leaking was to wear them so tight they gave me migraines. I upgraded to the second version this year and it’s a night and day difference in terms of comfort. I really have no complaints; the app is great, it has a huge workout library, and being able to see my splits without looking at my watch is great. Also, this is probably a niche use case, but they’re the best way I’ve found to track swims in swim spas and Endless Pools. I haven’t tried the other options, though, so I don’t know how they compare, but I’m pretty happy with them.
How is the visibility? Both with the HUD and also the peripheral?
Not great, to be honest. I only use mine in the pool; I wouldn’t use them for open water swimming and certainly not for a race. I also have the Pro version, which have Gorilla Glass, which gives them more durability but at the expense of anti-fog (they don’t have any), so they fog very quickly unless I reapply baby shampoo or frog spit before every swim.
Considering the Speedo IQ Vanquisher because I don’t think personally that the HUD will change anything for me mid swim but the post swim data will be nice to see outside of what the watch will give me. Also not need a subscription is a plus. Really tired of being nickel and dimed for every single thing possible.
For me, the advantages of the HUD are that having my workout in my goggles is just way more convenient than having them written on a piece of paper on the side of the pool or whatever; it also makes it easier to keep track of how many lengths I have left during longer sets. Form also has some real-time feedback features for things like how much I’m tilting my head or turning to breathe, which have helped me to some extent since I don’t have a coach. It’s also kind of cool to see the impact of changes to my technique in my splits in real time. The real-time aspect of the Form goggles is a big part of the appeal for me; if I could only look at the data after the fact, I might as well just use my watch (that said, I haven’t looked at the Speedo system so I don’t know what data they provide that my watch can’t).
Head position, etc in the HUD plus remaining lengths would be nice since I often zone out and lose track lol. The speedo will capture the same head position data, I believe time back to head down after breath, etc which is very similar, just won’t show me in real time. I’m not sure if this would distract me during the workout or not to be honest.
The other advantage to the speedo is that if the goggles wear out, simply get another set of vanquisher goggles and pop the unit in versus replacing the entire computer.
Well, a nice thing is that the Form screens are pretty customizable. You can set up different dashboards that you can switch between with the button on the goggles, and within each dashboard you can set up different metrics for the swim, turn, and rest screens. I have one that I use for intervals that is mostly time metrics, and another when I want to focus on technique that mostly has the form feedback.
If the data is distracting, you can also set it up to turn off the screen while you swim and only show metrics during turns or rests (I just hide the heart rate in the display, it stresses me out to see it in real time).
this is a separate issue but are there any watches out there that beep on a pre-set frequency, that you can use for swimming?
Yeah, my Garmin Forerunner 970 has a bunch of options like that. I have mine set to alert every four lengths during pool swims, and every 100 m during open water swims and races.
what are you in venture capital? I just looked at the price and that would be more expensive than my computer ![]()
Well, I went with the Speedo IQ Vanquisher goggles. First swim yesterday with them was just like any other swim. Visibility is not impacted at all, setup super easy and I think i’m happy with the choice to go with goggles that DO NOT have a HUD. Data in the app is pretty cool to see with 3D animations to show you what’s happening. First impressions pretty positive so far.
If all you want is audible beeps during your swim, look at using this. Variety of setup options depending on what you are trying to work on: https://www.finisswim.com/Tempo-Trainer-Pro
You reckon that will work?
Tempo training is great tool for training. Has three modes of operation.
Summary:
mode 1 training tempo
In a pool - set timer to time you want to hold for one length of the pool. Goal is to hit the wall on the beep. great for helping hold pace through a longer swim.
Mode 2 - set time for your send off - do your swim, leave on the beep.
Mode 3 - stroke rate or tempo. Set time to match your stroke rate. Either every stroke or every stroke cycle. hand enters water on the beep.
From Finis:
USING THE THREE MODES
MODE 1
Primarily for monitoring and setting your stroke rate or
tempo.
• Set the Tempo Trainer Pro to beep every XX:XX
seconds
• Time ranges from 00:20 (0.2 seconds) to 99:99
(99.99 seconds), scrolling by hundredths of a second
• Gives a SINGLE audible beep between 00:20 and
4.99 seconds, and a DOUBLE beep between 4.99 and
99.99 seconds
• The colon [ : ] in the middle does not flash
MODE 2
Primarily for monitoring and setting pace times for laps,
distance or intervals.
• Set the Tempo Trainer Pro to beep every XX minutes
and XX seconds.
• Time ranges from 00:01 (1 sec) to 9:59
(9 minutes, 59 sec), scrolling by seconds
• Gives a TRIPLE audible beep
• The colon [ : ] in the middle flashes
» TIP: Look at the colon [ : ] in the middle of the display
to determine which mode you are in.
MODE 3
Similar to Mode 1, this mode is primarily for monitoring
and setting your stroke rate or tempo. However the Mode
3 setting is in “strokes or cycles per minute”.
• Set the Tempo Trainer Pro to beep in strokes/
strides/cycles per minute
• The interval ranges from 10 to 300, where values
10-120 scroll by single integers, and values 120-300
scroll by units of 5
• The colon will not be displayed
TIP: If you were to set Mode 3 at a value of “75”, then
the Tempo Trainer Pro will beep evenly at a rate of 75
times per minute (beeps every 0.80 seconds)
I have the same problem with version 2 and overall I don’t think I enjoy the HUD as much as the clear freedom. I keep meaning to try them again otherwise it’s an expensive brick and not even a good one that that.
Also the splits to me were always so off - sometimes it counted the turn as the next lap etc so I’d have a 2-3 second addition to my laps - very inconsistent. Like pushing off the wall to start I’d swim 1:35 then the next 25 would be 1:55 pace. I don’t think I was that inconsistent in my stroke.
I got the goggles a week or so ago, and I’ve only had a couple of swims. Comfort wise they’re perfectly fine for me, so happy days.
I also notice the slight delay in splits. It never messed up the lap/lap count, but my first length is always far and away quicker than the rest, and the delay between stopping and the rest counter starting is 3-5 seconds.
The first time I swam with my watch going as well, and overall it was close enough that it didn’t really bother me, but you’d think a simple software patch to maybe adjust the first and last length to account for the delay in the goggles starting/stopping would be easily done.
Overall I’m pretty happy with them though. I love tech and will happily get the next thing to keep me (more) interested in the exercise. Especially swimming.
