SLS3 Race Sox and Compression Sleeves
**Product Review by – Steve Larsen (steve@worldtri.com) **
Although I have yet to try every brand on the market, I think it would be fair to classify myself as a connoisseur of compression gear. From the first compression gear I tried I was surprised by the results. Since then I have had an opportunity to try many others in a wide range of products including tights, race socks, recovery socks, calf guards, compression sleeves and even compression shorts and tops. I first tried SLS3 Race Sox and sleeves about a month ago. They have become a favorite ever since.
**The comfort and ease with which they went on was immediately noticeable. The manufacturer claims this is from their use of Polypropylene instead of nylon. In their words; “**Polypropylene, the material we use, absorbs 300 times less water than Nylon, the material of our competitors. This is why we are the only brand that can be worn from the start, in the swim keeping your legs light instead of weighing them down.” I have yet to swim in them but I can say that they wick moisture incredibly well, which is absolutely a positive in the late stages of training or racing. Comfortable feet are dry feet and these Race Sox have kept me dryer than any other sock I have run in.
The level of compression I felt was also immediately noticeable and it has continued to be consistent even after twenty or so trips through the laundry. The compression is the key and here is how the manufacturer describes the technical side of their product:
**“**Compression is measured in mmHg. This stands for millimeters (mm) of mercury (Hg) and is the average measurement of compression firmness at the ankle.
There are different levels of compression possible.
8-15mmHg offers a very, very mild compression.
It’s preventative and helps with minor fatigue and cramps.
15-20mmHg offers firmer compression.
It helps with mild foot and leg swelling, tired and achy legs, and prevents several mild varicose problems.
20-30mmHg is where SLS3® comes in.
SLS3 Compression Sleeves average around 26-28mmHg. This is considered firm compression that helps with severe swelling, reversible lymphoedema, moderate to severe fatigue and cramps, and severe vein insufficiency.
Above this there is yet more compression to be had BUT it is for medical indication such as irreversible lymphoedema and elephantiasis
What was noticeable to me was the level of support I feel, while not feeling my movement inhibited in the least. The Race Sox are a bit thinner than my normal running sock and perhaps due to lessened swelling, I have actually moved down a half size in my run shoes.
The compression sleeves are probably a bit more practical for most on race day and from my experience they offer a comparable level of support. The manufacturer claims “The special material used for the SLS3® Compression Sleeves is designed to keep you cool when wet due to sweat or extra water applied on the Sleeves. The cooling effect will you to keep your body temperature down ( especially in extreme hot races like Hawaii ) which results in an improvement of performance.”, and I am eager to try them under such circumstances. With the 50+ UV protection, you can be sure that your new compression tan line will not be compromised.
On the performance side, the results seem to back the manufacturer’s claims as SLS3 claims more top ten Ironman finishes than any competing compression brand. Most recently garnering 1st place in the women’s race and 3rd in the men’s race at Ironman South Africa.
*** Sizing: SLS3 Race Sox and Compression Sleeves come in two sizes:**
Unisex, two sizes:
Small/Medium fits 5’0"-5’8"/maximum calf circumference 14"(36cm)
Large/XLarge fits 5’7"-6’4"/maximum calf circumference 17"(43cm)
*** Price: A couple of bucks more than some competing brands, and worth it.**
**SLS3 Compression Race Sox – MSRP $57.95, available at www.worldtri.com **
**SLS3 Compression Race Sleeve – MSRP $44.95, available at www.worldtri.com **
Overall, I am very impressed by the products I have tried from this manufacturer. It is clear they are passionate about their products and it shows in the end result.****
