Slowtwitch Polls
Who designs them?
They really are very poorly designed - so poor as to be absolutely worthless and a waste of time.
Let’s take the current one
your tri bike crank length, compared to your road bike’s crank, is or soon will be: shorter longer same length whatever came on the bike don’t care
If you can’t see a real problem with this, it isn’t worth trying to explain to you.
You may be right, but to add your poorly-designed post (one that easily 99% of folks won’t understand) to poorly-designed polls only compounds the problem.
you may be right, but to add your very poorly-designed post (one that easily 99% of folks won’t understand) to poorly-designed polls only compounds the very problem that you are fond of pointing out.
Hey, yeah I agree, I had copied the poll into my post, but it hasn’t shown up when “published” It viewed fine in preview, I didn’t check after that.
Anyway, the point is - the polls are pathetic. Take the current one
My cranks are different, and also what came on the bike, which option do I choose? And even if I could choose both, how do we know that I would not want them different or the same or otherwise.
Every poll has a bunch of questions were most people could tick several boxes with a valid response.
The results are useless.
