ccy, here is my race report that I sent to a local online forum. Here it is:
Peterborough is always a tough race. In the words of race ogranizer Mitch Fraser, “I try to create conditions as close to Kona as possible in Ontario”. It was our first “hot day of the year”. There were lots of dudes melting down in the heat. Except in my age group. It was stacked with a bunch 9 hour Ironman studs. Steve Bentley, 9:08, Allan Faulds 9:27, Marc Flageole from Montreal 9:40 and Richard Isnor, 9:44. I had some serious competition…
Swim
600 person mass start, first turn at 475 meter. It was insane at the turn buoy. I made the critical mistake of starting wide to the right, and got on a good draft but when I made it to the turn, we were 10 abreast and I had to swim 15 m passed both turn buoys. Dumb strategy. Should have started on the inside like LP and taken a straight line. The swim is 2x1K loop, so on the second loop I swam on the inside and my second swim split was 15 min even. First split was just under 16. I thought the swim might be a bit short, but all the top studs like Isnor and Eric Roy were in the 27 min range, so it must have been the huge 600 person draft pulling people to quicker swim times. We had a huge long run to the transition. They changed the set up from last year. By the time I got to T2, is was just over 32. I had some of the fastest T1 and T2 transitions of the day…free speed. I was satisfied with the swim
Bike
I never got going in the bike. I’ve never been in a tri where I passed pretty well no one on the bike. It sucked. Why ? I’m not sure, but I think I figured it out on Monday morning on an easy 25K recovery ride. I had changed my cranks for my trip to France last weekend and put on a 50x34 set with a different Q factor. I had to readjust my cleats a few times on the previous weekend’s ride to get them dialed in, but I think on the last adjustment I did not tighten the cleat very well as on the way home from work on Thursday, the left cleat moved, when I had to do a sudden emergency exit. I tightened the cleat later, but I think it moved forward at that point. I really should have checked it out, but I was not doing any riding between Thu and Sun, so I never did, assuming it was Ok. Anyway, for the whole ride I felt that I was pushing the pedals with my tippy toes with the left leg and could not get any power to the pedal. I was unable to do my usual "stomp on the pedals ". Around 30K into the bike I kind of figured out what was going on, so I decided to go as fast a possible at 95-105 RPM, fuel up for the looming “meltdown run” and see if I could run fast off the bike. Realistically though, I was really dissapointed in this as I had felt that my biking was really gettting stronger in the past two weeks. On Monday morning, when I rode, I moved the cleats back…and I had power again. I could stomp on the pedals. Goes to show you that you really need to be thorough !
After 20 years in triathlon, perhaps you get a bit complacent with your gear and just ‘wing it’ cause you have done it so many times. Bad idea ! Final bike time was 2:32. I was hoping for more like 2:28. My only consolation from Mitch Fraser was that this year’s bike ride was 5 K longer than last year (ie last year was 85K, but a bit hillier). Guys like Allan Faulds were ~4 min slower than last year. Still, anything slower than 2:30 was unacceptable.
Run
By the time the run came along, it was getting close to 30 degrees (or so I am told), hot sun, not an ounce of shade on course and the light wind on the bike had died down. My legs were OK given the lame bike ride and high RPM riding. I had my best run of the year, passing tons of dudes (of course, when you pass no one on the bike, you pass lots of dudes). I came in at a high 1:32. This was the 17th fastest run split of the day, in a stacked field that had over 15 dudes that have gone sub 9:45 at various Ironmans. I did suck up the pain on the run and was on the verge of blowing up at all times. This was the perfect example of pulling out a good race from something that was going downhill in a hurry. I passed the final 35-39 year old with 200 m to go to sneak onto the 5 man podium and get a plaque for my effort. This was a race that proved the theory that if you do the mileage and believe in yourself, even when things are going bad, good things will happen. NEVER GIVE UP AT ANY POINT IN THE RACE>
As expected, the aforementioned sub 9:45 studs all beat me. Guys were croaking all over the course. It was stinking hot. Final time 4:39.00, 21st overall. Arguably my worst time in years, but based on dudes like Eric Roy going 4:30 even, I can’t complain. I’ll be back to Peterborough next year. I need to get some revenge on that bike course.
Next up, no racing for 5 weeks then:
Thousand Island, Ottawa Half Ironman, Duke Half Ironman (NC), Westchester NY tri, Ottawa Fall Colours Marathon (5 races in 7 weeks) YIKES !
Allan Faulds was totally studly, spanking everyone in our age group with an incredible 1:25 run split when only 7 guys went sub 1:30 on the run. He snuck into the top 10.
To reconfirm my status as a triposer, I am now going to drop some cash on Guru Trilite in Aug. Now I will be one of those true posers with a Kestrel Road bike (that I currently race on) and a Guru Tribike. I really don’t deserve to have two bikes until I can break 2:30 again in a half Ironman !
Dev “triposer” Paul
