Slowman's future tire testing
In Slowman’s article on tires at Kona he states:
We have not yet tried the Schwalbes, but intend to give them a go over the Winter. Further, we’ll be doing a set of roll-down tests. We’re blessed with the archetypal Soapbox Derby hill in our proximity, it’s straight as an arrow and 4% for 4 uninterrupted miles. We’ll test the Hutchinsons, Michelins, Continentals, as well as Vredesteins and others, and we’ll report here on Slowtwitch.
Umm…I’m thinking that he’s going to have a hard time controlling aerodynamic variables in that type of testing. Humans and their clothing can tend to be “big floppy things” (that’s a technical aerodynamics term).
IMHO, it would be better to find a slightly steeper hill and do tests UP the hill at a constant power output. The aerodynamic forces are minimized and the power required to raise the total weight against gravity is easily calculated.
Anyone else have thoughts???
I don’t think he has power measuring devices, which is why it’ll be downhill.
In that case…I’m not too encouraged about seeing anything “meaningfull”. But that could just be me…
C’mon Slowman…we’re already 6 years into the 21st century! Time to get up to speed… :slight_smile: Do you mean with all your bike industry contacts you can’t scare up a power meter to use?
Hey, if it were up to me, I’d just buy all the tires, then send them to jens and name him Official Tire Guru of ST. He has the methodology down pat. The rollers are definitely the easiest and most consistent way to test…
I will be one of the guys doing this test, and Dan and I have talked about the protocals. It will be a lot like wetsuit testing, not perfect, but may yield some trends over a large sampling. I think we should do a non pedaling start. Kind of like a soap box racer start. That eliminates any acceleration differences. As for clothing, I will wear something tight, and we will stay in the aero bars to keep the positions in the wind fairly constant. No moving around or tucking, and a constant head position. Of course we will check tire pressures, wheel types and sizes, and tire wear for consistancy. The roll out is a long one, and the speeds should approach 40mph, so I would think that any differences will be magnifyied enough to show some patterns. Maybe not, but we will give it a try. It worked for the wetsuit trials over the years, and measuring the difference between full suits and long johns was a small gap. But we found it…
Oh…but then you have to take the “leap of faith” that rolling resistance tests on a curved drum correlate to rolling resistance results on a flat surface…even though every tire manufacturer (not just bikes) does exactly that.
Where’s that emoticon when you need it…
Maybe take the crank off and put a bar through the bottom bracket to rest your feet on. That way you’ll have a consistant foot/leg position.
I take many leaps of faith, so I’m not too worried. I have taken that massive leap of faith on curved drums, wind tunnels, and many other such dark and magical instruments, so I think I’ll be okay! :wink:
Monty, the problem which I see with this test has nothing to do with differing aero positions for the entire descent. The main problem I see is that at 40+ mph vast majority (almost all of) the resistance is due to wind. The differences due to rolling resistance will be marginal, and I don’t know if they will be significant. You will have to run a lot of tests for each setup in order to reject the null hypothesis that they is indeed no difference between the various tires.
Regarding wetsuit tests. I am more than willing and eager to hep you with the testing. Let me know how I can help.
Think about this…you’re trying to measure relatively small differences in a value that changes linearly with speed. However, it will be “overshadowed” greatly in that case by another retarding force that varies with velocity cubed and that has the potential to vary greatly during the testing.
Here’s a simple test case I just simulated over at analyticcycling.com. Assuming a rider + bike weight of 85 kg, a “tri-average” CdA of 0.30 m^2, and a downgrade of 4%, if the tire Crr is at .004, your terminal velocity down the hill will be 12.77 m/s which works out to 28.5 mph.
If you then change the tire Crr to .0045, which is a 12.5% change in the Crr, the terminal velocity (assuming everything else is held constant) works out to 12.69 m/s, or 28.4 mph. So…to detect a 12.5% change in the rolling resistance, you need to be able to resolve and detect a 0.6% difference in your speed.
Now…that’s operating under the HUGE assumption that you can “hold everything the same”, especially the aerodynamics of the situation. What happens if we change the CdA by just 5%, in other words it goes from .300 to .315? Well, keeping the Crr at .004, that means the terminal velocity drops to 12.47 m/s (27.9 mph). That’s a 2.1% change in the speed for a 5% change in the CdA.
All I’m saying is that for this type of testing you’re going to have a hell of a time keeping all the aerodynamic variables (i.e. position, ambient winds, etc.) consistant enough to get anything meaningful out of the testing…even with a large number of runs.
But…like I said…maybe it’s just me…
Edit: spelling and grammar
we’re going to test all kinds of things. same hill, lotsa stuff.
as we roll from 0mph to 35mph over 3 miles the effect of the various media over and through which we’ll travel will change. in the case of tires, we’ll have several sets of identical wheels various sets of tires. we’ll swap them back and forth between us, and each test will require several trials by each person. we’ll measure the gap between the riders at the finish.
it won’t be a protocol without its detractors, but i personally think this sort of field testing has been missing from our industry’s efforts to differentiate between products. so we’ll present the data, and you guys can read it or not read it, and you can also pick apart the protocol, but i think you probably ought to see the finished product before you pick it apart.
not that i think certain of you actually will wait.
I’m not trying to pick it apart…I’m just trying to point out obvious pitfalls so that all of your effort isn’t “wasted”. I commend you for taking the initiative to tackle the subject…but I also hope you’ll thoroughly think through the process before hand to see if your plan of action is actually going to be able to “see” what you’re trying to “see”.
IMHO, the worst thing that could come out of all your efforts is a “we couldn’t tell a difference” opinion since people will latch onto that…rather than realizing the difference wasn’t detectable due to measurement uncertainties…
There’s a lot of smart people who could help refine your testing so that differentiation would be more likely, if it exists. I’m not saying I’m one of them…but there certainly are a few folks who read this stuff that could help immensely…
Yes, the difference in wind will be incremently higher at the faster speeds, but as I said, there will be no pedaling, and I will hold a static position. And it will be the same each time. I want to simulate all ranges of speed during a race, from the dead stop, to the coasting on a dwonhill, or tailwind riding. Of course we will try and make sure that the actual wind does not change, otherwise that will throw the tests off completely. Have to go another day in that case, but we have a lot of no wind days out here. I will be a virtual dummy on the bike, and it is easy to put my forearms and butt in the exact spot each time. That will force me to be in the same position. Just have to be careful not to sneeze
I’d agree with Tom that grabbing a PM from somewhere would be the way to go. However, if you’re committed to doing it sans PM, you should really give some of these testing protocols and spreadsheets a look.
No sense reinventing the wheel–and the HPV guys take this stuff pretty seriously: http://www.ihpva.org/tools/index.html
Yes: science should be left to scientists, not bike/swimsuit-makers-turned-journalists.
That’s a classic… I’ll have to preserve that one in case The Big Cheese tactics return…
Actually, showing that there isn’t much difference from different tires is the BEST thing that could come out of this test. That way we could focus on important things rather than making a run on whatever tires someone says roll better (or whatever crank or frame Tous says is stiffer).
I like the protocol. It’s closer to the world we’ll live in than a wind tunnel. We do move around on the bike and perhaps those changes are more important than whether we use clinchers because they are supposed to roll better.
Keep us posted Dan and Monty.
Homeboy gets himself a set of Dugasts and sets the fastest bike split of the day (by over a minute) at the Fl 1/2 IM. Now he’s all about CLINCHERS?
http://forum.slowtwitch.com/gforum.cgi?post=1055088;search_string=tube;#1055088
Hello Tom A. and All,
How about an altogether different plan?
http://www.canosoarus.com/08LSRbicycle/LSR%20Bike01.htm
1. Set up a rig like John Howard used in the record run above.
2. Attach a sensitive scale (with a remote recording feature) in the horizontal axis of the bicycle to tow the bike (not at 152mph of course - unless you have a death wish), using values more like 20, 25, and 30 mph.
3. Use the same rider and bike each time as you swap out the same wheels with different tires. (You might be able to rig a test dummy rider that would be in exactly the same position for all tests - and you could add weights to test various rider weights)
4. Variations on a theme might be towing over different road surfaces, on wet and dry roads, over ground glass and tacks, and perhaps make the wind shield variable so that it could provide crosswinds at various yaw angles to test tire scrubbing.
5. Some advantages of this approach would be the ability to get relatively steady state readings at real world speeds over long time intervals.
4. Record the results. Repeat. Repeat. Repeat. Repeat…
The results would probably have monetary value. It is information we would all like to have. Depending on how generous you are feeling… (Perhaps we could all contribute some cash to help the effort).
Also IMHO it would be wise to consult with those who have done tire tests with rollers and power meters and so on to see what kind of correlations developed.
Also assign a Public Relations Officer to deal with disappointed tire companies that would like to send you to sleep with the fish after you publish the results.
Roll on …
Cheers,
Neal
Science happens in the bike industry? Who funds it?
I’d rather trust some semi-neutral guys having fun rolling their bikes down a hill than marketing in a lab coat.
