Three good questions, as usual.
Q: “Seat angle is the center of the bike position.” — Can you clearly define ‘seat angle’, even ‘dynamic seat angle’? I.e., how exactly do you measure it?
My A: Seat Angle, Tom’s definition: The angle described by an imaginary line originating at the center of the bottom bracket and extending upward to any number of coordinates subject to the intended use of the angle, i.e. there is **frame **seat tube angle (the static seat tube angle of the bike frame’s seat tube relative to the horizontal), **pelvic **seat tube angle (the angle described when the line ends at the intersection of the femural head as it plugs into the pelvis) and then the dynamic seat to angle, which is the “arc” through which a rider moves fore/aft on the saddle as mission requirments change (i.e. changes in pedal rate, pedal force, etc.). An example of this is: What is the dynamic seat tube angle of a riding climbing out of the saddle? It could be well in excess of 95 or 100 degrees as their pelvis moves forward (such as a Armstrong like climbing posture with hips very far forward at a high, choppy cadence).
I measure this angle using different techniques for each measurement or angle type. Basically, for frame seat tube angle you “flat patch” the bike and make sure the bottom of the wheels are on level ground then just determine the real position of where the center of the bottom brakcet is and then the center of the exit hole for the seatpost is. This is often different than the leading edge of the seatpost, so you have to be careful with this. I like to use a big, long level to put the angle finder against to read the real frame seat tube angle.
Measuring the pelvic angle is tricker since, as soon as the rider begins to pedal, the Pelvic angle then becomes the dynamic angle and will start to change. You can measure it the same way you do the frame, but what is the reason to do this? It will change as soon as the muscular geometry changes as the muscles fatigues. The Wobblenaught guys can probably see this happen. Short of their methodology, other techniques for measuring this may be accurate in a static sense, but probably not of much value the instant the rider begins to pedal.
Q: “No science to bike fit? That is wrong. Bike fit is not “art”. It is science in the very strictest definition of the term “science”.” — How do you support this statement? What studies have been done on seat angle (or dynamic seat angle) that have put the examination of this parameter in the realm of science? Please give references to these studies as I would like to find them and educate myself.
My A: Bike fit is a science because, done correctly, it adheres to the definition of scientific investigation and method:“The observation, identification, description, experimental investigation, and theoretical explanation of phenomena” That directly describes good fitters on-going interaction with fit and positioning.
Just one example of a formally conducted seat tube angle scientific investigation, in the academic sense of the terminology, is the “Garside Study” conducted by Ian Garside and Dominic Doran correctly refered to as “Effects of Bicycle Frame Ergonomics on Triathlon 10-km Running Performance.” as published in the June 2000 issue of the *Journal of Sports Sciences. *This is most easily referenced as paraphrased in Dan Empfield’s FIST fitting manual and is just one example of a study conducted using normally accepted scientific techniques as defined above. There are others but I don;t know them off the top of my desk.
Q. “There is no one “correct” or universally “best” seat tube angle for everyone.” — This seems correct, but how do you know this for sure?
My A: I know this for sure because the dimensions of each person’s skeleton and the physiological configuration of the attached musculature is unique. Those, along with additional mechnical factors, are the determining factors in establishing seat tube angle. Given that this set of variables alone is arguably nearly infinite, then the interpolations/extrapolations of that data to determine the appropriate (optimal) seat tube angle is likely also infinite to a commensurate degree.
Q. Have you or anyone ever done a good study to verify this?
A. I haven’t ever conducted a formal study of this, and I’m not certain that anyone has. Realisitcally, I would suggest it isn’t necessary. I mean, do we all agree people come in different sizes? Do we all agree that seat tube angle (whatever type of seat tube angle you are discussing) is predominantly related to body dimensions? Given those two assumptions (facts?) I would suggest such an investigation would be largely redundant, i.e., there isn’t much need to do a doctoral disertation on the existence of gravity or the theory that the earth is round.
Q. Has anyone done a study to show that the optimal seat angle is different for everyone?
A. I don’t know. I think they have. Dan and Gerard may know the answer to this question.
Q. How can one even scientifically determine the best seat angle for one particular person??
A. This is the “meat” of your question. I’m not telling how I do it because it is a proprietary service that I sell and I don’t want it borrowed, stolen, perverted, misunderstood and defamed ad nauseum. But I will offer this insight: The technique I use is no better and no worse than any other system in current use and the same as some with some additions. That said, the best technique is still not that great. It could be much better. Again, based on what I know about it, I will argue the best system is a Wobblenaught style system where there is some empiracle protocol and apparatus for reading what the muscles are doing and then making changes and observing those changes. In the strictest sense of the scientific, empiracle way to observe, change and evaluate seat tube angle and its effect on performance, I will suggest theirs is the best. They are the only ones using a device to measure muscle actuation and observe it while pedalling.
Q. Wouldn’t you need a wind tunnel and a sophisticated powermeter to determine the truly optimal seat angle for one particular person?
A. I guess that depends. Do you want a strictly biomechanical answer or a more realistic answer as applicable to the road environment? My thoughts are that once the biomechanical parameters are established and optimized, then the aerodynamic optimizations can be considered PROVIDED they do not compormise the biomechnical prinicples. There has to be some interplay between these two principles (aerodynamic and biomechanical) and a third factor that influences bike handling in the real world: i.e. the best Computrainer position will likely not be good on the road since it is probably not optimized for aerodynamics or steering and stability and sublties lie reaching for a water bottle while pedalling.
Q. And then, again, how in the heck do you even measure the angle? Everyone seems to do it differently.
A. Well, I did read Dan’s article on figuring out if a bike fitter is any good and I am almost entirely in agreement with it. I also agree that there are some people calling themselves “bike fitters” out there who need substantial additional education and experience before they shoulder the responsibility of fitting someone to a $1500 + bike system. Since bike fit is the new “in thing” a lot of guys are cropping up saying “I am a bike fitter!” and also buying a host of entertaining theater props to support their performance. There are some good theater props out there too: Adjustable bikes and stems that look very impressive and laser apparatus with computer screens and all manner of quasi-medical looking gadgets that enhance a “bike fitters” credibility or at least perceived credibility. I would suggest, especially right now, the majority of it is theater. That is the answer to your question of why everyone seems to do it differently- or at least a part of the answer. Another part of the answer is that there are several ways to establish such a measurement. As long as the person doing the measurement produces accurate, precise, repeatable data and understands the significance of it for their fitting protocol then I would suggest their version is acceptable. That I am aware of, there is no consensus though.
Whew. I hope that answers your (good) questions.
Happy New Year!
