I saw your post about the down time for work on the search engine, but I still can’t get any results searching by username. Not fixed yet?
The forum software apparently doesn’t like usernames with ampersands in them…I’m don’t know if slowman can come up with a workaround for that limitation.
I have no idea what software slowtwitch runs on, so this may be wildly off-base. Have you tried putting a \' character before the ampersand? This is a common convention in many systems where &’ is a special character; in these cases the presence of the back-slash indicates that the following (usually special) character is to be treated as a regular character.
we reindexed the database. it took about an hour, between 6PM and 7PM this evening. it was supposed to happen yesterday, but was delayed until tonight. everything should be fine now.
Did you get the PM I sent you about the Slowtwitch ™?
It works perfectly. You never realize how valuable a resource is until it’s gone. Thanks Dan.
Ken
