I trialled a pair of Rotorz and found after giving myself a 2 week period to adapt to them, that on the flats I was faster. These were the older RS3 model and they had been lent to the AIS (Australian Institute of Sport) and they had not been looked after all that well. Anyway they were faster on the flats (I did 4 12km TTs before and 4 after and nearly shaved a minute) but noticeably harder to climb in. Because of the cams and extra moving parts, these cranks have some resistance and don’t spin freely, when back spun, like normal cranks but normally the resistance is unnoticeable when pedalling. However the unit itself had a lot more resistence than normal because of the maintenance issues.
I now have a pair of RS4 Rotorz and all these issues are gone and they are just as easy to climb as normal cranks. I believe the RS3s would have been too, after the unit had been given a good service. I purchased the RS4s because they were lighter and had made improvements with the bearings and so on. Who wouldn’t?
Anyway, Frank Day’s idea of “back pressure” while not exactly a myth, is something I would expect see only in untrained cyclists, children or adults that ride on platform pedals, or someone with poor motor skills (perhaps a congenital condition). As a child I rode a bike and as matter of survival, to keep my feet on both pedals I maintained some back pressure. I noticed after I’d started attaching my shoes to pedals (first with toe straps and then clipless systems) that when I rode unattached I had to slow down my cadence or my feet would spin off, up and over the top, the same area Frank Day is claiming this back pressure would occur. Hence my doubts that this really applies to trained cyclists. What the studies that I have seen show is that even amongst trained cyclists, even elite ones, is that they are weaker through this area, especially over top-dead-centre. This is where PowerCranks are a good training tool. They will improve the power through this part of the pedal stroke (and I’m sure there are more benefits!).
In the 90s there was a technique of training on longer cranks and then racing smaller ones. Brad Bevan and a few others were doing it. The idea was that because you were spinning a smaller circle and not lifting your leg as high you would close this “gap” of power reduction over top-dead-centre and have more power all the way round the pedal stroke. Also because the actual linear velocity for the same angular velocity (RPM) is less you could spin a slightly higher max cadence. This strategy is fine for olympic distance triathlon, it doesn’t matter if the extra force required blows you up after 2 hrs because the race is over by then. For longer distance races though it is going to lead to exhaustion sooner.
When moving to a longer crank length there is the apparent benefit of extra leverage, requiring less force to turn the cranks. There are a couple of down sides too but nothing serious. The first one is the opposite of the above situation. Longer crank means a longer circumference and more linear distance to cover. Your legs have a maximum speed at which they can move, so according to the physics this means your max cadence will drop. I would expect on average most people can get to 140rpm and hold it for a up to a minute, the drop would be around 8rpm going from 170mm to 180mm ((340x3.14159x140)/(360x3.14159)). Now, I don’t know about you, but I don’t pedal in either racing or training at anything remotely approaching that cadence. I pedal at a cadence between 85-100RPM. So the reduced maximum never comes into play and is never a limiting factor.
The other downside is that by going to a larger crank, the “gap” of reduced power over top-dead-centre is going to be longer. This is simply because, at least initially, you are not used to, moving your legs through the extended range, that is you have to lift your leg higher (and lower but that is not where the problem is). With training of course, on the longer cranks, this gap can be closed back up again. This is also where RotorCranks help. The whole aim of them is to reduce the gap, by accelerating your foot through it. So it is now possible to go to a longer crank, eliminate the gap, get the advantage of better leverage, and increase the power phase of the pedal stroke. RotorCranks are for racing not training. They give you a mechanical advantage by accelerating your rising foot over top-dead-centre by piggy backing a ride from the end of the power phase of the opposite foot.
I have the titanium RS4s and I couldn’t be happier with mine.
