Slow twitch geometry
My question is directed to Dan, because of his ability to give us frame geometry info that is understandable,but if any others have ideas please join in.
Background. I ride a M size Giant Trinity.This is my first non road geometry bike,and after 6 months of riding it can say I love it.Very fast ,comfortable,and in most conditions;stable.My seat is as far forward as it will go so S.A. is between 76 to78 deg.Using the first
large spacer under a 100 mm. stem, low pos.Bar is Easton base with VisionTech S bends,rests with low spacers.
In this position I am low,comfortable, and after 4 hrs can get into a good run.
Looking thru Dans ideal geometry, I see the most obvious difference is the wheelbase no.Slowtwitch ideal for a 54/56 frame is 99.8 t0 102.4.My bike is 95.2.Some of the difference is in the Giants short chainstay,but I am wondering if the rake and trail and 73 deg. H.A.also are a factor.Specifically,is there an after market fork that would give me a longer wheelbase,and perhaps even give more downhill high speed stability.
The bike is not scary at speed ,but hills steeper than 8 deg.can get a
bit shakey.
Sorry to be so long ,but I joined this forum in part because of all the info on fit and geometry.If there are no forks that would give me more stability and a longer wheelbase I will eventully look at a different frame. Thanks in advance.
I don’t know that any fork is available that would stretch your wheelbase more than a few millimeters. Plus, even if such a fork were available, it would drastically reduce your trail (maybe even make it negative!) and make the bike extremely twitchy.
“Specifically,is there an after market fork that would give me a longer wheelbase,and perhaps even give more downhill high speed stability.”
don’t change the fork. you’ll reduce the trail and end up with a bike worse for the change. if the bike works for you now, just go with it. while i prefer giant’s new trinity alliance geometry, it sounds like you and your bike (and its geometry) have bonded. i wouldn’t worry.
