I race juniors, so i run a 45 tooth big ring and a 12-21 cassette, and really, have never had to shift out of the 45t in a TT, is there any reason i couldnt use a track ring on the front and do away with the front derailur, shifter cables, and have a narrower q factor, and lighter weight?
David Millar did the same in a TDF prologue. He had won if the chain hadn’t fallen off because there were no front meck holding it in place…
thats true, but he had a road chainring, they are made to shift, i would use a track ring, it might work better
A track ring will work fine if its adjusted correctly and the course is not bumpy. Make sure that the ring is centered. Make sure that the chain is as sort as possible. It would be a good idea to put on a chain watcher also.
Styrrell
A better choice would be a 53t ring with a 14-25. The added engagement of the additional teeth on the ring would provide more security, and you’d have less drag as a result of the increase in friction of the roller chain going around the tight circumfrence of a 12 or 13t cog.
Of course you could always just run one cog out back too and go O’bree, Pate, D’Antoni style. Those guys have all won huge TTs with a fixed gear on the road.
-SD
the 45-12 rolls out at exactly 26 feet(the limit), the 52-14 rolls out an inch or 2 short, its not much, but enough to matter in a TT.
change the tire to a Michelin clincher. How do you know the roll out w/o the tire?
I’ve used a 54t x 14t on an 18mm Tufo and that falls under the roll out.
the narrower tires have more rolling resistance and i do not plan to change from my setup (sponsored for tires), my gearing will stay, because not only does it have a rollout closer to the 26’ mark, but its allot easier to find a 12-23 cassete than to find a 14-… cassete.
I don’t know where the track ring enters in. I don’t see how it would have made any difference in my circumstance.
I raced with just a single chainring and no front derailler for my state time trial championship this year. I’d raced the bike that way a number of times before with no problems. However, the state TT course started with a gentle downhill. I don’t believe in starting out too highly geared and, unfortunately, with that slight downhill, I found myself shifting through the gears on the cassette very rapidly as I left the start line. That set the chain dancing and then I had that wonderful feeling of “no chain.” Problem was, it was 'cuz I had no chain. 100 meters off the start line at the state championships I had to stop, dismount, remount the chain and get going again. I still managed to win in my age group and set a personal best time, but I’d sure like to have the time back that I lost … at least 20 seconds and maybe more.
I doubt I’ll ever race without a front derailler again. There’s never a good time to lose a chain in a race and the time you’ll gain if you don’t lose a chain could only be very minimal.
standard road chainrings are made to shift, they have shorter teeth everynow and then and ramps and pins, so natrually when the chain starts to go, on a standard road chainring, it shifts off the gear. http://www.sheldonbrown.com/images/ramps-pins.jpg I know this as fact, and if i were to use a standard road chainring, i would, of course, have to use a front derailur to hold everything in place.
My question was if i were to use a track ring, http://130.94.226.209/Chrome/Nail/84.jpeg with much taller teeth, no short teeth, no pins and no ramps, would i need a front derailur?
To answer your question (sort of), you’ll have a better chance of retaining the chain with the track chainring as you surmise, but it is unlikely that it will be foolproof. As the OP suggested, run the chain as short as possible to maximize tension, and also shift gears 1 deliberate shift at a time. You may get away with it. I used to run my raod bike with only a single front ring. It worked well…except for those few times that the chain dropped. As another OP suggested, why don’t you consider a fixed gear?
I presume you are running track cranks, and not just chain-rings? you will need to check the chain runs on the track ring OK (they are made for a wider chain). I would leave the front mech on and use it as a guide, even if you take the cables and lever off. For less than 100gms, probably worth it in reliability. I know a few others that have ridden with just one front ring, and they have all dropped chains, and now ride with the front mech - not conected to anything.
I used an old record front derailleur with my single ring setup. No cable or shift lever and just adjusted the screws to accomodate the chain variation from the rear cog. You could even put a longer screw in the back of the cage of the derailleur to spread it out a little wider. I didn’t take out any links in the chain, but I was riding a 54. I rode a 3/32 pitch (road) ring and chain, as it was explained to me, a 1/8 pitch (track) would not make any difference with the bigger rings but the smaller the ring, the more an 1/8 pitch will give you some difficulty with a 3/32 pitch chain. Don’t know that for sure, but something to look into. Anyways, it didn’t make a difference with Q-angle, though. Just helped reduce rotating weight as far as I could tell. Never had a chain jump off with that set-up.
I remember jr racing and roll outs. Like the above poster, I used a 53/15 with a single ring on the front and a ft der not connected to anything as a backup.
I was not known to be a sprinter. I remember winning a field sprint one race, shocking everyone including myself. At roll out I found out that I forgot to switch my freewheel (remember those) from the senior race the week before. 15-21 six speed was actually a pretty good set up.
The rolling resistance on a 25mm tire is less than that of a 23mm. The rolling resistance is not the only issue at play here. At high speed a 19mm tire can be faster on the right wheel than a 23mm.
Do you think it is easier to find a track crankset and a 45t 3/32" track ring, or a 14-25 cassette?
No problem running one ring up front, either road or track, but I’d keep the FD on there just to make sure the chain doesn’t jump off (don’t need to runt he cable, just tighten down the limit screw to keep it in the right place).
14-25s are easy. They’re in the QBP catalog. The 45 tooth 3/32 track ring might be tougher.
