Silverman swim data?
Monty, question for you…is sleevesless wetsuit a touch slower than sleeved, mainly because the “size of the paddle” on the forearm, or because the upper arm is more buoyant, kind of forcing you into a higher elbow position?//
Both those things and the fact that the suit is now completely closed. Could also be a tiny bit of compression too, but not really much on the arm, but more in the lat shoulder area. All my tests came out to a second or just above for difference in full vs long john, and if you missed your optimal group because of a few seconds in the beginning, that could have ballooned up a bit by the finish.
And your 8 minutes behind gomez was a much better swim for you too. He would have been in the 22’s at silverman, so you were just off and swimming in slower stuff is my final answer…
I’m not complaining and don’t care about the time because in a swim there’s obviously lots of variables (although considerably less in a lake than the ocean) so placing is a better metric. I just found it odd that a 31:2x was good enough for almost top 5% of what is usually a very competitive age group (and which is higher than I usually place AG wise in 70.3 distances)
