Silverman 2006 ROLL CALL (1)
NOTE: It appears I put Silverman in twice, use the last one in the list, the one WITHOUT “ST” in the title.
Go here http://migrate.rockfordtri.com/STDB/index.php
If you have been previously entered into the athlete list simply click “Modify Athlete”. On the next page use the pull down to select your screen name and on the right select “Silverman 2006” and then “go”. You should then show up on the list below.
If you were not previously on the list simply click “Add Athlete” fill in your screen name and other info and “Go”. Then follow the instructions above to add yourself to the race…technically you should show up here when you reload the page.
Good Luck everyone!
http://migrate.rockfordtri.com/STDB/image.php?Type=img&RaceID=8
bump
Good luck everyone!!!
