Well, I’ve been running a standard Campy front Der. with my compact cranks for over a year now, and the setup works about 90% as well as when I had standard size cranks.
10% is a bitch.
I did a stage race this weekend - Mast. A’s.
Won the TT, and fell into second after the crit due to the time bonus sprint (I finished 5th in the crit, time bonus for top 3…)
It all comes down to the RR.
Finish is about 3K of false headwind flat after the main climb of the day, which is about 5k long.
I’m the best climber in the field, and I KNOW I can open the gap on the hill.
I’m in good position, the field hits the last k of the climb, I get out of the saddle, shift to the big ring, and…
…nothing.
I’m still in the 36.
I can’t get into the big ring until after the top of the climb.
I climb the last bit of the climb in the 36x12 or so, but it’s just not enough, and they bring me back right after the top.
I’m looking at getting a 52 x 36, and switching out my 52 x 42 x 30. I was kind of hoping I could get away with my current derailleur, but maybe 16 teeth is just a bit too big of a jump…
Is there only one compact specific derailleur out there right now?
It’s not the gap, it’s the radius of the ring; the der. wants to see a certain size ring when it goes up for the shift, and it ain’t seeing it with the 50…
There are 2 different compact specific fdr’s on the market, the IRD and the Campy. Both will work with either Campy or Shimano shift levers.
Thanks for the post, but really, I don’t need mechanical advice.
I’m a certified bike mechanic, a machinist, a master level sawyer, have designed bike frames for a living, build and repair complex musical instruments for pay - and, oh yeah - I was the customer service/warranty guy for the company that manufactured my cranks. I know what I’m talking about.
90% means your shifting is perfect until that one day when you really, really need it. You just haven’t had that day yet.
Sorry. My mistake. I assumed that you were posting an actual request for advice from the forum. I see now that you were merely posting race results thinly disguised as a request for advice.
I have one on my rig. I am only pushing 48/36. I think the huge gaps between the 50/34 guys is a lot to ask for a front D. At $40 it is a pretty good deal as well. Not as purdy as Campy, but pretty nice.
Since it sounds like you are an expert, what do you think of using one of those ‘triple’ front derailleurs like a shimano ultegra on a compact? Do you think that would help avoid the chain dropping off to the inside?
“I’ve been running a standard Campy front Der. with my compact cranks for over a year now, and the setup works about 90% as well as when I had standard size cranks.”
Record will be pissed, but chalk a point up here for Shimano. My ShimaNO front der. works 100% as good with compacts as it did with regular size cranks.
