I often hear/read people refer to how important shoulder flexibility is. What constitutes flexibility with respect to swimming? Being able to reach overhead and squish your ears with your biceps? That isn’t much of a feat. Or is it the ability to get your elbows close together behind your back (which would allow a really high elbow on recovery without needing to roll the torso as much)?
Klehner has mentioned that he doesn’t have much, yet he swims like a torpedo*. So what does flexibility really do to help your swimming? I suppose it could allow you to start your pull farther forward, if you had the flexibility to keep the elbow up way farther out in front of you. But I’ve yet so see anyone prescribe stretches for that position.
How do you get it? by SWIMMING - and stretching to some extent, but really just swimming will keep your shoulders in shape.
what is it? I don’t know how to put it into words. I think part of it is being able to really reach out and elongate to get the most out of each stroke… like if you watch good swimmers when their arm is out in front of them before pulling down, it looks like the shoulder is almost hyperextended.
Shoulder flexibility is basically for your health and not a performance (in terms of velocity) enhancer. In fact, all this talk of HYPEREXTENSION is the reason that I say that. There is a common theme in the swimming culture that coaches and swimmers alike continue to cling to (in this REACHING/HIGH ELBOW mentality). Contact any local Physical Therapy clinic and they can prescribe several stretches for your shoulders that will help you. (could probably find them online too).
To answer your issue is to look at a couple of muscle groups that are always OVER engaged in swimmers and then those that are totally shut off.
While online look into your upper pec (pec minor) muscles and scalene (neck) muscles, for stretches that are focused there. These are common areas where (aquatic) people store tension.
In terms of muscles that are commonly shut off, see CORE muscles. If you think I am joking, take a look around at swimmers on the pool deck. The FASTER they are the better, and notice 2 things…a small ‘belly’ just below the navel and rounded shoulders with a protruding chin.
All the best,
Daved
Dave, there are two things that make my shoulders hurt when swimming. The first is stretching out long then catching the water and pulling. Second, pushing my arms through with high elbows. Both hurt the front of my shoulders. Are you saying I shouldn’t be doing these things?
Tim,
Seriously, is this a joke?
Kinda like when the guys goes in to see the Dr bc his eye hurts everytime he drinks his coffee, and the dr says “take the spoon out of the cup first!”
If you are not joking, then yes. Stop doing those things.
daved
No, what he is saying is that your catch is wrong if you are feeling shoulder pain in the anterior deltoid.
does that help?
In shape, sure, but not flexible. Kind of like you wouldn’t suggest running to someone to help their hamstring flexibility.
Daved commented on the “reaching/high elbow” mentality. I was attempting to say that both of those things cause me soreness in the front of my shoulders. But it seems that both of these things are all you hear about in swimming circles.
My question was should I not be reaching or high elbowing? Or maybe the correct question is: if I am getting discomfort in the front of my shoulders, am I doing something wrong with my catch or high elbows? If so, what? As I sit here at my desk and kind of walk through those motions, I can’t see how the frontal shoulder area cannot be involved.
Ok, fine.
Yes, stop doing that. If you are horizontal on the water surface, then your elbows are higher than your hands (unless you are REALLY trying to pull the back of your hand towards your shoulder).
High elbow and over reaching are both examples of HYPER EXTENSION. Full extension is fine. Think of when your foot impacts the ground when walking. IF the knee is locked (or hyper extended) it doesnt feel so good. So there is some ‘play’ in that joint. I call it functional. But whatever you want to call it. IMHO, the elbow does not go past full extension in either direction (stretching out or collapsing). Keep your elbow joint ‘engaged’ through the entire stroking process. There should not be moments of hyperextension bc at that point your arm is useless, so you are gliding (or not producing forward velocity) and thus slowing down. Then you have to RE-start. Then your HR goes up and you start lurching, as I call it. I see it all the time. If you watch people swim you will see it too. Small little ‘stops and starts’. Not good.
All this focus on arms is testament to reinforcing my ideas that keeping the arms simple and putting our focus else where, is the key to velocity maintenence and improvement. Good questions, but avoid that shoulder pain, please. Dont like to hear that!
DaveD
Since I can’t see you I’ll still take a stab at this. My guess is that you are reaching too far allowing your elbow to rotate down a bit before starting your catch. The elbow needs to be facing the side wall before you start to stroke and there should be a small bend in the elbow. If you extend as far as you can, you elbow naturally (or mine anyway) wants to rotate so that the distal end of the humerous points down. From this position when you go to get into a high elbow position the tendon of one of the deltoid muscles rubs over the humerous. This is probably where your pain is orginating from. You may be able to feel a popping or snapping in your shoulder when this happens.
To excute the catch and hopfully eliminate this, when you enter, slide your shoulder forward while you extend the arm. Extend so that there is a small bend in the elbow. Allow the hand to drift down slightly, this will pop your elbow up then and only when your hand is below your elbow should you begin to press on the water.
So you should be reaching but not to much, and you should have a high elbow position. I hope this helps.
I dont believe that your shoulder should extend at all. If you are reaching, say, to get a coat off a hook and you just can’t quite get there…then you extend more from your shoulder (slide your scapula up (in swimming that would be forward)) you are now MORE prone to injury. As you know, there a so many small muscles and tendons running through and around the shoulder (the most complex joint in the body)…so to extend your shoulder and put more strain on them, is IMHO, not good.
daved
I don’t have much flexibility in my shoulders (or anywhere else for that matter). I broke my collar bone without realizing it a few year ago, and it didn’t heal exactly right, which makes the lack of shoulder flexibility even worse. You know the stretch where you reach behind your head with one hand and behind your back from the waist with the other and grasp hands? I can’t even come close to touching fingertips, let alone grasping hands. When I was having a lot of problems from the collar bone (thoracic outlet syndrome), I got a couple of intense shoulder massages, and the difference in flexibility was amazing. I could easily grasp hands behind my back, and my swim stroke was much more fluid, and felt really natural. It was much easier to keep my hand close to my body (think ‘zipper’ drill), and I swam more ‘narrow’. I only saved a second or maybe two per 50, but it felt really good, and my shoulders and upper arms were much fresher after swimming. Unfortunately, the flexibility only lasted 2 or 3 days after each massage, and no amount of stretching on my own seemed to maintain it.
DD, by what you’ve written, I would think then that a ton of rotation at the shoulders would be a bad thing. It would only make that elbow want to point downward all the more. Maybe that helps 'splain why my shoulders feel better when I swim a bit flatter than my default stroke.
I don’t think you are grasping what I am saying or I am not grasping what you are saying. You can not swim effectively with out some sort of movement through you shoulder joint. Try this.
Stand up. Without any lifting of your shoulders, raise 1 of your arms, with a slight bend in your elbow and your elbow pointing out to the side. You notice it does not go very high. This is what I think of when reading “I don’t believe that your shoulder should extend at all” in your post. This is neither efficient swimming nor conducive to fast swimming.
Now raise your arm, with your elbow bent some and elbow pointing to the side. Keeping the bend in your elbow, extend you arm further overhead. That movement through the shoulder to get the extended extension is what I’m talking about. Re-read my previous post on how to begin your stroke properly from this position.
