Hi All-
Being the one who was sidelined the most with ITB- can anyone beat 21 mos- I agree with most of the posts except I would say that until your ITB gets better you should not build you bike and even your swim. I made the mistake of building the other areas going with the philosophy “if it doesn’t hurt you can do it” but thats not necessarily true since it can keep those glute medius muscles tightened. I would also really caution you about running until you “feel the pain” I did the same thing running until I felt it and then icing it but if you flare it up you have to calm it down again. I ended up with chronic inflammation with scar tissue that surgery finally had to take care of. After surgery, I started back running 1 min x 4 and building from there. I would agree with the other posts of RICE, foam roller and PT but in addition I would get a proper bike fit, stay away from the aero position for a bit, and keep your other disciplines steady and not build.
Just be smart with it- I was under the idea that more was better and couldn’t fathom taking time off and I watched my injury go from 2 weeks after marathon to 21 mos. Good news is that now I am up to 55 miles on the bike, running 11 miles, and 2 mile swims with no pain. Good luck and just go easy!
You asked if anyone had suffered longer than 21 months. Here’s my story and solutions. 19 years ago, I got ITband syndrome that lasted for several years!!! I had been a three times a week runner ( 5 - 10 km) and woke up with it one day after jogging from my first job (as a bank clerk) to my second job (catering attendant) in my pumps (I was late leaving my first job and needed to run across the university campus to start my second job which was about 2 km away). I actually passed another jogger while I was wearing a skirt, long winter trenchcoat, and carrying a backpack, briefcase and unbrella and as i said earlier my high heeled shoes.
I don’t remember being diagnosed with ITB, but from that day on couldn’t run more than 5 km. About three years later i found i was able to play soccer and then football. i guess the short sprints were okay but i was disabled with anything longer. Needless to say, rest did not help either.
10 years ago, i started training for a 1/2 marathon and was then diagnosed with ITB. I did the ITB stretches and found they didn’t help at all. I continued to run only to the point that i could feel it and slowly built up my mileage. A few years later of running when i could and not when i couldn’t i finally found that quad stretches and some hamstring stretches helped the most. So for several years of having ITB i found i was able to run, and when my itb bothered me, i would stop and stretch my quads and could continue on. I spent several years using orthotics and slowly built mileage and now can run fairly consistently. I’ve long since abandoned the orthotics. I did two marathons last year with no issue, but did find the muscle to the back and underneath the itb - toward the hamstring - will cramp up if i run on a bad camber.
My solutions
I found the explanation given with The Trigger Point Therapy Workbook - Claire Davies - available on-line to be most helpful in getting this turned around.
Gradual increase in mileage
no high heels (i think it shortens the muscle above the knee and on the outside??i’m not a physio, but have a tonne of experience with this affliction)
Vary the terrain - some hills, some camber (not too much) and course. I will go to the track or treadmill to get some camber free running in. Reverse direction at the track every 2 km. On an out and back, I’ll try to run on the wrong side of the road on the way back to even the camber. Avoid a route if the camber is too severe.
One new exercise i was given by my massage therapist also helped me strengthen the muscles to handle the camber. With feet pointed out at 45 degrees and heels close together, bend the knees slightly) - maybe there is a pt or massage therapist that can describe this exercise better. Helped me out a tonne.
I was running so well last year, i had the confidence to sign up for IMC. I’ve since had a heel problem, which i think i now have under control, but the it band is so much better.
Belinda
